rx330 starting/electrical problems. Please help
My parents are disabled and have a 04 rx330 awd with 80k on it. its not running and Im trying to help them. here is the problem.
CAR HAS A BRAND NEW BATTERY.
I can unlock the doors, get in the car and try to start it. When key is turned as far as it will go without starting the car the cluster lights up, all warning lights come on. but thats it. Radio, climate control, windows,seats, NOTHING else works. Then when you turn the key to start it nothing happens, Not even a click. power outlets dont work.
things I have tried.
NEW BATTERY
CHECK FUSES
ROCKING THE ROCK IN PARK
STARTING IN NEUTRAL
nothing as worked. Any info would be great. Im pretty much lost now.
PROBLEM IS FIXED, SOLUTION ON PG 2
NEW BATTERY
CHECK FUSES
STARTING IN NEUTRAL
BTW, is there anything else on the keychain in addition to the Lexus key such as a security fob or any other RF device such as a Mobil Speedpass? These devices can interfere with the electronics in the key. Try with just the ignition key and nothing else in the vicinity to include other ignition keys.
Even if there was interference from another source and the car couldn't read the security tag in the key, the car would attempt to "turn over" but you would just continuously hear the starter over and over because the fuel cut off is the only thing that stops when it doesn't sense the security part of the key... So you would hear some kind of attempt for the car to start, there just wouldn't be any fuel for it to actually start.
-Joe
-Joe
Try jiggling the gear lever. There is an interlock that checks the gear shifter is in Park.
There could be an actual problem with starter solenoid or wire leading to the solenoid. If you are handy with voltmeter and can keep your hands out of the moving parts, you can check for +12v on the solenoid when you attempt to start. If you get +12v and the relay does not engage, try hitting it with rubber mallet.
If you are uncomfortable with it, reach for a mechanic.
Salim
Salim
nothing on the key chain, I have tried both mater keys as well as the little sliver key.
tried messing with the gear lever.. I will check the starter solenoid today. where is that located on these things?
As you turn the ignition to start, 12v is sent to the solenoid, the relay part of the solenoid connects the thick 12v wire from the battery to the starter and the mechanical lever (bendix) pulls out the gear of the starter to engage with the flywheel.
Please do not be in a hurry to get the RX going. You really want to diagnose the problem as it would be worse if the the RX refused to start away from home.
If you can turn the ignition with any key, the key is not your problem.
Some times when some one says, the vehicle does not start, it can have multiple meanings ,,, the starter spins and rotates the engine but the engine does not catch (run) is one.
I am under the impression that the starter is not spinning and you do not hear the click-click sound (the when the battery is almost out of juice).
You may need a partner or a mirror. Humor me and turn the head lights ON and try to start. Do the head lights dim when you move the ignition to start?
Salim
I will try that now. I still dont think its the starter solenoid, because that doesnt explain why nothing in the car works..(seats,windows,radio,a/c. nothing but the gauge cluster.
That is good information.
I would suggest look through the fuses in the engine compartment. Some of the fuses are bolted in (due to high current demand).
Did any one put in the new battery the wrong way? +/- swapped. or any bad experience giving/getting jump.
Salim
Salim
