Replacement tires for '05 awd RX 330
This isn't a good year/ Went to the Lexus dealer for an oil change and came out with almost $4500 thousand in repairs. Lift gate motor is ridiculously expensive $1100. Strut, rear breaks, steering rack. My private mechanic will charge half. Any suggestions about the lift gate motor? Used?
Maintenance Moderator
So long as it is still a slight leak, I wouldn't worry too much about it right this second... Does it need to get fixed, sure, but so long as you keep fluid in it, it shouldn't be a huge deal... as far as the rattle - only when going down the road? the lift gate motor I wouldn't think would cause a rattle when closed, but suppose it could...
