Last edit by: IB Advertising
Browse all: Steering and Suspension
- How to Change Power Steering Fluid
Step by step instructions for do-it-yourself repairs
power steering fluid change?
i want to to steering fluid change but to expensive @ dealer ..so i cam across this one :
http://www.youtube.com/watch?v=UMLD9DAGS90
so this an ok thing to do?
i guess this would work too..just do it couple of times and u r good to go
Would at least think about using something other than Walmart brand ATF as shown in the video. Remember, you do not use Power Steering fluid. You need ATF. Though, you can use the Walmart brand if you have not done this previous. Especially, if the fluid looks like it needs changed as his did until you get the fluid looking cleaner. In the end, Mobil 1 ATF might be better as it is a synthetic. His process only removes a small amount of fluid from the system. You will want to do this a few times to truly replace all the power steering fluid.Some here will do what he did every time they change their oil. Easy to do if you are a DIY.
Just have a look in your Owner's Manual:
Power steering fluid type
Automatic transmission fluid DEXRONRII or III
Why I mentioned Mobil 1 ATF. Also, look at what he is using in the video... Dextron ATF.
I would add few steps.
1. Before you open up the cap, take a rag (dampen it wd40 if needed) and wipe the cap and sides of the of the reservoir down.
2. Rinse the tip of the turkey baster with fresh fluid. (to prevent contamination)
Follow the process
3 Do not introduce the fluid from the baster back into the reservoir.
4. At end of the process, start the vehicle and turn the steering to one side max and hold for few seconds and then turn the other side max and hold few seconds. This will purge any air (in case it did).
You can repeat the whole process after few months and couple of times more and you would practically removed old fluid from the system.
Salim
Follow the process
Salim
RuninRoach
12-04-14 05:13 PM
Purplexed
Maintenance
05-26-01 06:16 AM
