TMPS lifespan
Old 10-31-11, 11:56 AM
Kostyan
Kostyan's Avatar
Default TMPS lifespan
How long do TMPS sensors (mounted on each wheel) last? Due for new tire replacement and wondering if that will need to be replaced too.
Old 10-31-11, 12:08 PM
MC5Wes
Registered User
MC5Wes's Avatar
Default Sensors
I guess you could change them out if you wanted.
I have about 4 1/2 years on mine. And havent had any problems.
Old 10-31-11, 12:47 PM
kickin8
2IS/2RX/4RX
kickin8's Avatar
I heard it's about 7 years?
Old 10-31-11, 10:38 PM
pauljcl
pauljcl's Avatar
Do they use batteries? Otherwise (i.e. except for changing battery), why would they have a specified lifespan?
Old 11-01-11, 06:20 AM
mandyfig
mandyfig's Avatar
7~8 years is what I heard. The batteries are Lithium Ion and may last up to 10 years. It is unfortunate that they can not be replaced.
Old 11-02-11, 08:50 PM
arnieosp
arnieosp's Avatar
I've seen on Russian Lexus forum site some McGyvers actually sawed the TPMS sensors open, replaced batteries and then glued them back together. I guess, if you have time, why not give it a shot, if it doesn't work, you were going to throw it away anyway.
The original battery is Panasonic BR2450A
Attached Thumbnails TMPS lifespan-t_11062009014_943.jpg   TMPS lifespan-t_11062009010_199.jpg   TMPS lifespan-panasonic-br2450a.jpg
Old 11-03-11, 06:41 AM
mandyfig
mandyfig's Avatar
Good idea. These costs a lot to replace.
Old 11-03-11, 08:06 AM
RX330inFL
RX330inFL's Avatar
The sensors they use there are a bit more rugged than the ones we get here.
In America, your TPMS senors break. In Soviet Russia, TPMS sensors break you.
treefiddy9 (12-01-21)
Old 11-03-11, 11:56 AM
dcdyd
dcdyd's Avatar
$64 on eBay for 4 tires. I got one set fro my winter tires. Wait until temp to drop below 45F for start using the tire and will see how well it works.
Old 11-03-11, 01:12 PM
pauljcl
pauljcl's Avatar
Of course, you do know you must 'activate' the connection with your car computer for it to recognize them? Otherwise, you will get the warning signal staying on.
Old 11-03-11, 05:33 PM
dcdyd
dcdyd's Avatar
Yes, the local Lexus dealer charges $50 for activating those sensors. I have recorded all four IDs before those sensors were installed. I can also purchase ATEQ Quickset tool at $150 for this task to save the time driving to the dealer and also prepared for future change of the TPMS - still debating which way to go to myself.
Old 11-03-11, 06:14 PM
arnieosp
arnieosp's Avatar
Most of the Lexuses on Russian roads were bought here and shipped over there. BTW, one of the most popular subjects on the http://www.club-lexus.ru is "how to change MPH to Km/h, Fahrenheit to Celsius, and MPG to l/100km"
I am not sure if, after replacing the batteries, the sensors have to be re-initialized at a dealership or not.
Old 11-03-11, 10:37 PM
pauljcl
pauljcl's Avatar
Understandably (but regrettably) clublexus.ru is in Russian, which I do not read not understand. If you have seen the answer: how does one change from MPH to Km/h of F to C, or mpg to l/100km?
Old 11-03-11, 11:09 PM
arnieosp
arnieosp's Avatar
Its complicated. You have to remove the instrument cluster, remove the memory chip, re-program it and solder it back. There is a whole bunch of shops all around Russia that could do it for around $300.
Take a look at this video, it's in Russian, but you will get an idea of what's involved. I suspect that simply replacing the cluster with a one from Canada would be a lot simpler.
Old 11-04-11, 12:37 PM
pauljcl
pauljcl's Avatar
Thank you. Yes, one does get the idea from the video. What a pain in the neck... the BMW just requires one push of a button, without undoing anything.
Quick Reply: TMPS lifespan
