Switched out LEDs in door sills
Old 09-17-11, 11:00 AM
Gidovs
Gidovs's Avatar
Default Switched out LEDs in door sills
I have successfully switched out the LED in the door sills , takes a bit of work but well worth it, here's some pics I took while working on it.
Final result
Old 09-17-11, 12:13 PM
rcy
rcy's Avatar
Nice. How about a little more detail - like what kind of LED, how to switch it out etc.
Thanks.
Old 09-17-11, 04:28 PM
mowmow
mowmow's Avatar
yes I like to know more detail too, I thought the original factory is a wedge bulb that is sealed in, so this is different ?
Old 09-17-11, 06:18 PM
Gidovs
Gidovs's Avatar
I'm about to do the last two sills ill take more pics during the process to show how its done. The LED is a standard 3mm LED bulb (I replaced it with a bigger 5mm bulb) which is soldered to a small circuit board. The LED is focused onto a plastic piece which disperses the light to make it appear the plate is lit up when really it isn't , the light is coming from the side of the plate, kind of like when you shine a light into murky water. You have to do a little cutting with a dremel on the bottom of the plate, which is out of sight, so you don't have to worry about cutting into a piece of the car, no one will ever see it all in all, I only spent $4 dollars (4 LED bulbs) sure beats the hundreds of dollars it cost to buy new sills
Old 09-18-11, 03:03 AM
Howiefied
Howiefied's Avatar
Nice!!!! just wondering is the metal part hard to detach from the plastic? Mine is a bit dented and i was thinking of taking it to a metal fabricator to get a new one made up.
Old 09-18-11, 06:38 AM
draco
draco's Avatar
I would love to see a tutorial / walk through guide on how to do this. Waiting in anticipation. Well done Gidovs!!!
Old 09-18-11, 07:56 PM
exmeaguy
exmeaguy's Avatar
Nicely done. Can't wait to see the steps.
Old 11-11-13, 09:25 AM
JProdun
JProdun's Avatar
I guess the step by step never came through...
If some one has instructions and pictures and how to, please post!
Old 11-11-13, 10:00 AM
CJG
CJG's Avatar
Seconded!
Old 11-11-13, 10:36 AM
JProdun
JProdun's Avatar
Could this answer our question on the removal/installation?
Old 11-11-13, 10:43 AM
JProdun
JProdun's Avatar
Some info here as well, towards the bottom:
http://us.lexusownersclub.com/forums...nt-open-fully/
Old 11-11-13, 05:11 PM
luxe88
luxe88's Avatar
Just posting to bump this thread hoping OP returns with the how-to...
Am i correct is assuming the sills just pop out and the actual labor comes not from removing panel after panel secured with screws... rather the removal of sills is easy and the "hard" labor is soldering the led?
Spudo769
12-17-17 02:59 PM
XenonDepot
Club Lexus Vendor Marketplace
09-28-17 12:38 PM
subzero32
05-17-13 07:13 PM
Ciege
RX - 3rd Gen (2010-2015)
03-19-12 09:16 AM
beneteau
Lighting
05-03-10 12:48 PM
Quick Reply: Switched out LEDs in door sills
