2009 RX350 aftermarket double din headunit install questions
Old 08-19-11, 12:04 PM
cyclonus99
cyclonus99's Avatar
Default 2009 RX350 aftermarket double din headunit install questions
Hi all:
I just got a 2009 RX350 without nav, non-ML audio system. I am looking to install the Pioneer Avic X930BT as well as a backup camera. Here are the components I'm looking at getting:
Headunit:
Pioneer Avic-X930BT
Ipod Controls:
Pioneer CDIU-203V Ipod audio/video cable.
Steering Wheel Controls:
PAC SWI-PS
Backup Camera:
Boyo vtl425 ultra slim
Trim/Harness
I'm undecided on this. There are 2 options:
1) Beatsonic SLA-82A if I want to do plug and play, retain use of the factory amp.
2) JDM Toyota Harrier double din trim piece + Metra 70-8113 Toyota harness if I want to do factory amp bypass and use the aftermarket HU's internal amp.
Questions:
1) Silly question, but does the install of any aftermarket radio violate any warranty (mine is a certified pre-owned)?
2) Does anyone have any opinion about the two choices of using the factory amp vs doing an amp bypass? I have heard complaints about noise/hissing using the factory amp with an aftermarket head unit. I could save a good bit of money doing the amp bypass myself, and probably better audio quality.
3) If do an amp bypass, why would I need a separate metra harness? I have read on the forums that this harness is required.
4) Does anyone have a link to the wiring diagram for the the amp/speakers for this car?
5) Am I missing anything? Any other components necessary?
Thanks in advance!
Old 08-19-11, 09:48 PM
Carver
Carver's Avatar
I used the Beat-Sonic kit with my Kenwood 6960 and have had no trouble. No hissing or unusual noises. My 330 had the base radio as well. I used the Axxess steering wheel controller to restore that function.
I had mine professionally installed so I can't address your other questions.
robo
03-04-14 04:37 PM
cyclonus99
08-19-11 12:15 PM
Clear2Cloz
07-02-11 06:20 PM
tle05
08-13-09 11:22 PM
DY3VERSITY
01-16-08 11:58 PM
Quick Reply: 2009 RX350 aftermarket double din headunit install questions
