Go Back   Club Lexus Forums > Lexus Model Forums > RX Models > RX - Second Generation
Sign in using an external account
Register Forgot Password?
trailer hitch lexus PT228-48045 = toyota PT228-69045
Thread Tools Search this Thread Display Modes
Old 08-08-11, 10:05 AM   #16
groomerz
Trader Score: (0)
groomerz's Avatar
That is how they pay for all the complimentary courtesy cars, snacks and drinks while you wait. Lexus dealers have higher overhead so profit margins are higher. When you install it leave all bolts loose until they are all in, then tighten. In my original post there is a link to the install manual if it is not in the box. If you have any ?'s let me know.
This ad is not displayed to registered members.
Register your free account today and become a member on Club Lexus!
__________________
His 2002 LS 430 base Mystic Gold/Tan interior
Hers 2009 Rx350 AWD, NAV Matador Red/Grey int
groomerz is offline   Reply With Quote
Old 09-30-11, 12:14 PM   #17
dhuston99
Trader Score: (0)
Can anyone tell me how to tell if my RX400h has the factory towing package or if I need to buy the converter?
dhuston99 is offline   Reply With Quote
Old 10-03-11, 10:20 AM   #18
groomerz
Trader Score: (0)
groomerz's Avatar
find the wiring harness in the rear compartment. The plug will have 4 wires - white(ground), Green(right turn/stop), yellow(left turn/stop), Blue(taillight/license/side marker. If you have a test light check them to verify the condition by clipping the alligator clip to a good grounding point on the chassis or to the white wire and then individually to each wire when in operating mode eg. green when signaling left or applying the brake.
__________________
Old 10-10-11, 08:12 AM   #19
prowler97
Trader Score: (0)
prowler97's Avatar
Easiest way to find out if your Lexus has tow package is call Lexus 800 number and give them the VIN and they will be able to tell if you have the tow package or not.
__________________
Brian Richardson
Jupiter, FL
2006 Lexus RX 400h
2006 Mercedes Benz C230 Sport with 6-speed manual
1997 Plymouth Prowler + matching Trailer
2002 Mitsubishi Montero Sport (151k miles) - SOLD
1992 Mitsubishi 3000GT VR-4 - SOLD
prowler97 is offline   Reply With Quote
Old 05-11-12, 08:01 AM   #20
smassey321
Trader Score: (0)
I installed my Toyota hitch last night. I was surprised how easy it was. I got it for $220 from a local Toyota dealer with at 20% off accessory coupon found on their website. I picked up a Lexus hitch plug for $14 on ebay.
At the parts counter I asked for a Toyota hitch and they quoted out a hitch and wiring as 2 part numbers. This seemed odd and it turns out the southeastern parts distributor sells a re-branded Reese hitch. I did not want the bar around the exhaust so I requested that they order the OEM part number listed in the first post. It was only $20 more to get the real factory hitch kit.
Lifting up the hitch was easier than I thought it would be. The drivers side has a single stud hanging down. I lifted that side of the hitch, put the nut half way on to hold up that side and then was easily able to lift the pass side and install the rest of the bolts.
I was able to connect the wiring by only removing the tool tray. I reached in under the rear tray and pulled the wire harness loose from its taped location. I was then able to plug it to the hitch wiring by feel.
I removed the 2 plastic covers from my hybrid. The instruction say to throw them out but I plan to trim the edges and re install them.
The Lexus instructions attached in the first post mention that a tow bar is included in the kid. New Toyota and Lexus kits no longer include the tow bar.
smassey321 is offline   Reply With Quote
Old 05-23-12, 06:43 AM   #21
glassmanj
Trader Score: (0)
i know i'm just reposting some info but it saves some time for others. another tip on whether you have the tow package i believe is to simply look at your front radiator and look and see if there is a small additional radiator. that's the auxilliary transmission cooler. it's standard on the 2006 400h but i don't think very many other models. with it you can tow 3500# without 2000# i think.
also, another tip for finding standard features on a car is to go to selling sites like cars.com or the like and find a year and model the same as yours. i just bought a 2006 400h and found under the standard equipment it has the aux trans cooler listed. didn't know that when i bought it and simply found a similar car listed. i also searched other similar models like the 300 and 350 and didn't find any that had it standard.
and one final note on shopping online, no matter what site you are on, if during checkout they offer a REDEEM CODE or COUPON CODE box or whatever, before you checkout simply open another window and do a search for the name of the site you are on plus COUPON and many times you'll find a code. i just listed old car on cars.com and their fee was $55 (which is great as they give u carfax too) but i searched and within 30 seconds found a 20% off code and saved $11. for 30 seconds of work. i saved $200 on my last vacation with orbitz because i found a save $200 code for a weeks booking. took me 1 minute to save $200. many times you can simply get free shipping. means you have to work less for you money.
glassmanj is offline   Reply With Quote
Old 05-24-12, 03:25 PM   #22
lanb
Trader Score: (0)
Question - Is this a class II or class III hitch ?
Toyota PT228-69045 seems to indicate it is class II
http://www.trdtoyotaparts.com/script...dproduct=25926
and
Lexus PT228-48045 seems to indicate it is class III
http://www.factorylexusparts.com/ser...III-TOW/Detail
lanb is offline   Reply With Quote
Old 05-24-12, 07:45 PM   #23
glassmanj
Trader Score: (0)
great ? lanb,
from what i can find, it's completely confusing. this link has the grades,
http://www.hitchesonline.com/hitch_selection.htm
CLASS II is rated 350# tongue, 3500# trailer. and CLASS III is 500#/5000#. so by that all the available hitches are CLASS II. but all except the Toyota are listed *** CLASS III but are only rated at 350/500.
and this link says the difference is that CLASS II only has 1-1/4" hitch, but the Toyota says it has 2" so that's confusing.
http://www.etrailer.com/question-4107.html
the reality is, every hitch, including Curt, Uhaul, etc, for the RX models are all rated at 350/3500 and all has 2".
so imho, it doesn't matter. the RX is rated for 350/3500 with the tow package. *** long as your hitch is rated for that, and has the 2" opening, you're good.
Old 05-25-12, 01:35 PM   #24
andresatp
Trader Score: (0)
One more satisfied Club lexus reader, just installed the toyota hitch on my 05' lexus rx 330, no problems at all took me an hour! Thanks for the posts!
andresatp is offline   Reply With Quote
Old 05-25-12, 08:14 PM   #25
lanb
Trader Score: (0)
Yeah glassmanj, the class thing is kind of confusing.
Got the hitch today from a local Toyota dealer for $220 + tax (with 20% off accessories coupon).
Planning to install over the weekend. Fingers crossed.
On a side note, any recommendations for a not-so-expensive 4-bike rack (prefer ones that swing).
Old 05-26-12, 04:54 AM   #26
cartman57
Trader Score: (0)
cartman57's Avatar
Quote:
eBay Item number: 120919141560
Swings down and holds 4 bikes for $50, shipping is expensive though @ $25, hope it'll help
cartman57 is offline   Reply With Quote
Old 05-26-12, 02:43 PM   #27
lanb
Trader Score: (0)
Thanks, I will take a look.
Me and a friend (a mechanic with tools) installed the hitch and wiring today.
Hitch took about 45 mins. Wiring took about 45 mins as well because of the
numerous clips/bolts to remove to access the connector.
Any one know of a easy way to test the wiring ? The instructions talk of a
special service tool.
My $0.02 - I would recommend installing the wiring while u are at this even if you
currently do not plan to pull a trailer, just to be prepared / done.
Tip - The Toyota rubber hitch cap is pretty loose and prone to falling off.
Stuff it with a block of cut styrofoam to make it tighter.
Thanks to all for the excellent instructions/knowledge sharing.
Old 04-08-13, 07:10 AM   #28
woodenboat
Trader Score: (0)
Default confirmation about 228-4805 fitting 2009 RX 350
I found a site selling the toyota trailer hitch pt228-69045 \ pt228-4805 for $ 240+ shipping. I need to confirm that I'd be making the right decision.
woodenboat is offline   Reply With Quote
Old 04-15-13, 03:34 AM   #29
straasha
Trader Score: (0)
Yes, it is the right hitch. See the picture I took at post #11. The hitch is stamped with both part numbers.
straasha is offline   Reply With Quote
Old 04-27-13, 08:35 AM   #30
Happycoop
Trader Score: (0)
Quote:
What site? Please share as I'm in the market for an OEM hitch for our 05 RX330 as well. Any coupon codes needed or just a great deal?
Thanks!
Happycoop is offline   Reply With Quote
Similar Threads
Thread Thread Starter Forum Replies Last Post
Toyota hitch for RX350 aquatrax RX - Second Generation 25 09-07-10 08:34 AM
NJ Lexus Genuine Tow Hitch Class II - PT228-48045 seagirt RX350 / 330/ 300 / 400H / 450H Classifieds 1 05-03-10 07:19 PM
Class II or Class III tow hitch swedevb RX - Second Generation 2 04-25-10 06:58 PM
Wiring harnes for PT228-48045 hitch spike49 RX - Third Generation 0 05-07-09 06:11 AM
RX400h trailer hitch uthorns197 RX - Second Generation 5 10-04-05 06:49 AM
Tags
350, craigslist, fit, highlander, hitch, insider, install, installation, lexus, manual, pictures, pt22848045, pt22869045, rx, tow, toyota
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Join ClubLexus
Copyright © 2000-2015 Internet Brands, Inc. All Rights Reserved
Privacy Policy | Disclaimer | Terms of Use | JOBS
Get all contact info
