2006 RX330 - Checking the transmission fluid level
Old 02-23-11, 07:21 AM
jack19446
jack19446's Avatar
Default 2006 RX330 - Checking the transmission fluid level
What is the procedure for checking the automatic transmission fluid level in a 2006 RX330? I am surprised that this procedure is not covered in the owners manual. The manual describes how to check the coolant, power steering, and brake fluid levels, but not the transmission fluid.
The Engine Compartment Overview drawing on page 539 does not show the location of a dip-stick for checking the transmission fluid. Where is the transmission fluid dip-stick located?
Old 02-23-11, 07:36 AM
infinirx
infinirx's Avatar
Good question... watching.
Old 02-23-11, 11:57 AM
lexus114
lexus114's Avatar
well, this is how i do it; first off check it hot,dont mess around with cold checks. put the vehicle on a level surface i.e your garage,or any level surface. pull out the stick, (slide the stop over with your thumb first) and the level should read full,or close to it. hope this helps. some makes you have to check in nuetral,but i believe ours is park. also,note the condition of the fluid. it should be nice and red,and no funny smells.
Old 02-23-11, 01:15 PM
mandyfig
mandyfig's Avatar
The dipstick is located opposite the Oil dipstick.
As long as you do not have tranny leak, your tranny fluid level should be good.
In my case, I do drain and fill. The manual states the FILL quantity of fluid. I fill it up based on specs. That's how I know I have the right amount of tranny fluid.
Old 02-23-11, 01:22 PM
mandyfig
mandyfig's Avatar
I periodically pull the tranny dipstick to check on how PINK the fluid is. What I do is dub new fluid in a paper towel, then right beside it I dub the existing tranny fluid and I compare color. The closer they are to each other indicates that you have fresh fluid. I also smell it.
In time the old fluid will turn brownish, that means it is burnt and it will smell burnt.
My last drain and fill was at 30K and have 55K now and it still looks good. I will give it another 5K. I will drain and fill when I hit 60K or maybe even 65K depends on condition of the fluid.
I check my tranny fluid every month.
Old 02-23-11, 02:47 PM
clickart
clickart's Avatar
How do you drain the transmission fluid?
Old 02-23-11, 05:37 PM
gawhiteman
gawhiteman's Avatar
Hi. I just recently joined. Below is what I found from my manual.
CHECK THE FLUID LEVEL
HINT:
Drive the vehicle so that the engine and transaxle are at normal operating temperature.
Fluid temperature: 70 - 80°C (158 - 176°F)
a. Park the vehicle on a level surface and set the parking brake.
b. With the engine idling and the brake pedal depressed, shift the lever into all positions from the P to
the L (S1 ) position, and return to the P position.
c. Take out the dipstick and wipe it clean.
d. Put it back all the way into the pipe.
e. Take it out and check that the fluid level is within the HOT position.
[IMG]file:///C:/Users/GREGWH%7E1/AppData/Local/Temp/moz-screenshot-8.png[/IMG][IMG]file:///C:/Users/GREGWH%7E1/AppData/Local/Temp/moz-screenshot-9.png[/IMG]
Old 02-24-11, 10:18 AM
jack19446
jack19446's Avatar
Where is this in the manual?
Were you trying to post two photos?
Old 02-24-11, 12:18 PM
mandyfig
mandyfig's Avatar
HINT:
You probably have to convert your screen shot to a jpg or a pdf and attach them properly.
Old 02-24-11, 04:55 PM
gawhiteman
gawhiteman's Avatar
Default Dipstick Level
Sorry about that. Just wanted to attach the picture of the dipstick.
File Type: doc
Old 09-14-13, 12:23 PM
Ehucman
Ehucman's Avatar
My transmission fluid level is higher than the hot mark on the dipstick when engine is hot...does anyone think its still ok, or do i have too much fluid? Txs
Old 09-14-13, 12:48 PM
RX330inFL
RX330inFL's Avatar
How much higher? Did you look at the image posted for #10?
If significantly higher, then yes you will want to do something about it.
Old 09-20-13, 05:59 AM
Ehucman
Ehucman's Avatar
Originally Posted by RX330inFL
How much higher? Did you look at the image posted for #10? If significantly higher, then yes you will want to do something about it.
When the engine is cold, it showed level as if engine is hot.. And when hot, it showed even higher., so i took out 1/2 qt with a hand pump
Old 09-20-13, 06:00 AM
Ehucman
Ehucman's Avatar
I had same issue, i mean with the small leak. But i assume its high pressure car wash. So its normal.. Not sure
Old 09-22-13, 07:33 AM
Tammera70
Tammera70's Avatar
Default Thanks for DIY transmission fluid info
Good info. Thanks.
manifesto
05-05-18 10:23 AM
cal_alum98
Maintenance
03-14-14 12:53 AM
ISFer
IS F (2008-2014)
14
04-27-10 11:56 AM
ThePill
03-24-08 02:04 PM
mrekid
RX - 1st Gen (1999-2003)
14
01-28-07 08:41 PM
Quick Reply: 2006 RX330 - Checking the transmission fluid level
