08 RX 350 - 60,000 mile service DIY?
I'm very leery of 'lifetime' fluids. What they really should call them is 'within our warranty fluids', meaning the fluid will function fine for as long as the warranty period, thus protecting the vehicle manufacturer. In 200000miles when the warranty is long expired, I really doubt that the original fluid is performing as new.
Take this ATF-WS (the Toyota Automatic Transmission Fluid - World Standard). How can it be a 'lifetime' fluid in the RX350, but in the 400h (where it is used in the transmission and rear electric motor) there is a recommended change interval?
life time fluid is bs. Sure you can use it for the life of the car, but it doesnt mean it's good for it. If you drain a trainy fluid at 100k you can see how dirty it is compared to new fluid. And keep in mind that if your car doesnt break, the dealerships arent making money in replacing trannies or selling new cars.
I already flushed my tranny at 65k KMs. and I can tell a difference in color and feel.
somnoboy: in regards to the brake fluid drain. You have to drain the fluid through the bleeders and refill the reservoir with new fluid as you are bleeding until the fluid coming out of all 4 bleeders on the calipers are clear and not dirty. Also you should never let the reservoir run "dry" when bleeding so you'll have to bleed a few times, then fill up, bleed, fill up, etc etc. Best done with 2 ppl. If you let the reservoir run dry, it's sometimes a PIA to get all the air out of the system in some cars. Should take 30 mins or so with an experienced mechanic and an assistant.
Action - Brake fluid replacement
I know, I know, I'm asking for a lot. But it sure would be a great help. Thanks in advance to anyone who wants to share "the knowledge."
I have to laugh when i see people religiously take their lexus to their lexus dealer for service at relatively astromonical prices vs what local mechanics can/will do the same work for.I have owned 5 lexus cars over the last 25 years and have NEVER used a lexus dealer for a single thing not related to a warranty claim. I've had 30-60 and 90k services performed by non Lexus dealers and have only had ONE MECHANICAL PROBLEM in all those years...a battery finally died on a ls400 that had 100,000 miles on it. I had a 2002 RX300 where lexus wanted $1400 for the 90k service and my local top notch mechanic did it for $950! I finally traded that car in with 134,000 miles on it. I have always kept meticulous records of all oil changes and other work performed locally and my current 2010 RX350 now has 33k miles on it and runs flawlessly since the day it was new. I will have my local guy Roger do the 60k service at a fraction of what the ripoff Lexus dealers want to do it.
Hope this helps a little Somnoboy.
for my 2004 RX330 to have it's 90K...their price is 435 for timing and drive belts and 225 if the water pump is leaking and needing replacement....I'm in love!
Registered User
If you spend the extra money for a Lexus instead of a Toyota. You also prefer to be babied at the dealership. Lattes, Massages, loaner cars. My old dealership would bring a loaner to your house. Pickup your car. Then return your car later.
Service costs money. If you dont want it. Dont pay for it. If your time is more valuable than doing it yourself. Then by all means have the dealer do it.
Think of it as stimulating the economy. The dealership owner has to send his kids to college too.
