Oil filter recommendations?
Old 10-18-10, 11:27 AM
  #31
somnoboy
somnoboy's Avatar
Originally Posted by lexus114
just as 330inFL mentioned,it doesnt hurt a thing. (I do reset the ecm though) helps in the re configuration process.
Thanks for the tip. Why do you reset the ecm? (Also, how do you reset the ecm?)
Old 10-18-10, 11:31 AM
  #32
lexus114
lexus114's Avatar
i reset it via my obd II scanner. it just helps the motor adjust to something different a little faster. i.e going from 87 octane to premium,or visa versa i reset the ecm. is it rally necessary? not really,just something i prefer to do.
Old 10-18-10, 01:45 PM
  #33
RX330inFL
RX330inFL's Avatar
Originally Posted by RX330inFL
No. Switching brands, weights, nor oil type (conventional, semi-synthetic, synthetic) will not cause any problems as long as it meets the spec noted in your manual.
While this thread is about oil filters, thought I would drop in this link for an article discussing some of the new motor oil specs as a follow up on my post above.
http://www.autoweek.com/article/2010...NEWS/101019902
Old 10-18-10, 02:51 PM
  #34
somnoboy
somnoboy's Avatar
Thanks 114 and RX330.
Old 10-18-10, 07:07 PM
  #35
rcy
rcy's Avatar
Reconfigure what? I guess if you are switching from high octane to low octane this might help, but switching from synthetic back to conventional or vice versa?
The engine has knock sensors that may or may not be retarding the timing if the lower octane is causing knock, but there is no sensor that can tell if you're running synthetic oil or conventional oil..
Old 10-19-10, 06:34 AM
  #36
lexus114
lexus114's Avatar
oh here we go.
Old 10-19-10, 01:02 PM
  #37
rcy
rcy's Avatar
"Oh, here we go." what?
Old 10-20-10, 06:29 AM
  #38
lexus114
lexus114's Avatar
Okay rcy,what I`m saying is:I have run Synthetic,and conventional oil in my current RX as well as the 01 RX I had prior. I have noticed when going back to conventional oil after using Synthetic,the motor is a little doggy. Not much,but enough to notice a difference (which in time,will re adjust itself). I simply reset the ecm after the oil change,but before I start the vehicle,and then it runs fine.BTW,I dont do this when switching from conventional to Synthetic. As I mentioned above ^^ do you really need to do this?? no,It`s all a matter of personal preference. The OBD II system is a complex system,(much more than previous years) Do you follow me now? And when I say doggy,it`s more like not quite as responsive. Some people may never even notice a difference, I on the other hand do. Same thing applies when switching octane fuel,I do the same procedure. But I have decided to stay with the Premium fuel because it just over all runs better.
Old 10-20-10, 04:00 PM
  #39
rcy
rcy's Avatar
I totally understand why you would do this when switching from lower octane to higher octane (the timing might be retarded due to the lower octane causing knock) and it will eventually advance the timing when the knock goes away with the higher octane but resetting the ECM manually will result in the advanced timing faster.
I still don't get what parameter the ECM will be adjusting/resetting that is affected by conventional oil vs synthetic oil. But, if it works for you, great.
Old 10-21-10, 07:08 AM
  #40
lexus114
lexus114's Avatar
It`s all good my friend.
gebo
Maintenance
10-06-17 08:00 PM
fsdoll
23
05-22-06 10:19 AM
Jmai22
Maintenance
58
11-09-04 06:51 AM
lex400sc
Maintenance
01-30-03 09:42 PM
damnboy
Maintenance
02-02-02 10:43 PM
Quick Reply: Oil filter recommendations?
