RX400h 2006 Headlight replacement
Old 08-29-10, 06:34 PM
finefotos
finefotos's Avatar
Default RX400h 2006 Headlight replacement
HI, I have a 2006 RX400h. Both of my highbeam lights went out at the same time. I called my area dealer and was told it would be $1000.00 to replace both lamps! I am amazed by this. I am assuming this means replacing entire units. What ever happened to popping in another bulb? Can anyone tell me if this is a possibility and if it can be done in my garage? Are there written instructions as to how to do it?
Thanks
Old 08-29-10, 09:39 PM
arnieosp
arnieosp's Avatar
Did your lights go bad simultaniously? If yes, it could be something other then bulbs. If one at a time, then probably bulbs. I am not sure if 06 400h has HIDs on high beams. My 08 350 has HID/low and halogen/high. Regardless, if it is just bulbs, replacing thm is very easy DYI.
Old 08-30-10, 06:41 AM
mandyfig
mandyfig's Avatar
Thanks
Assume you are out of warranty?
Old 08-30-10, 06:07 PM
finefotos
finefotos's Avatar
Thanks for the responses. I am out of warranty, of course. I am not sure if they both went out together or not, either together or within days. I don't know if they are HID's, but I expect so since they are expensive and that could be the reason the dealer is as well. I'll check that and see if a friend can look at them for me to see if there are two types of lights present.
Old 08-31-10, 05:25 AM
phlfly
phlfly's Avatar
it's more likely HID bulb. Dealer is charging about 200-300 per bulb plus work. Check your fuse before doing anything else.
Old 08-31-10, 07:01 AM
ycl1688
ycl1688's Avatar
definitely the dealer is getting ridiculous, I would first check the switch, if okay will buy the bulbs with the following link as guide, if it works you can buy 100 years worth supply of bulbs
http://www.sylvania.com/ConsumerProd...odelSelect.htm
Old 08-31-10, 08:03 AM
Adamjeeps
Adamjeeps's Avatar
If it is your high beam bulb, it is a 9005 bulb and they are very cheap, about $10. You can replace yourself, instructions are in my 2007 RX 350 manual. Are you positive it is your high beams?
2006 LEXUS RX400h (With HID (high intensity discharge) headlamps)
Low beam headlamp
HID-D2S
High beam headlamp
9005
9005SU SilverStar Ultra: The brightest and whitest light. Up to 50% brighter, up to 40% more downroad visibility and up to 50% more sideroad visibility.
9005ST Silverstar: The brighter and whiter light. Up to 35% brighter, up to 30% more downroad visibility and up to 35% more sideroad visibility.
9005EB EcoBright - Your Environmental Choice. Save Energy - Save Money. Up to 25% brighter light. CO2 reduced 9 to 21%. Gas savings $2 to $19.
9005XV XtraVision: The brighter light for upgraded performance. Up to 30% brighter light and up to 25% more downroad visibility.
9005CB Cool Blue: The whiter light for style. Up to 25% brighter light and up to 25% more downroad visibility.
Parking light
168
168LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Front turn signal
992 (7440A)
992/7440AL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Rear turn signal
992 (7440A)
Tail light
LED
Stop light
LED
High mount stop light
LED
Fog/Driving light
9006
9006SU SilverStar Ultra: The brightest and whitest light. Up to 50% brighter, up to 40% more downroad visibility and up to 50% more sideroad visibility.
9006ST Silverstar: The brighter and whiter light. Up to 35% brighter, up to 30% more downroad visibility and up to 35% more sideroad visibility.
9006EB EcoBright - Your Environmental Choice. Save Energy - Save Money. Up to 25% brighter light. CO2 reduced 9 to 21%. Gas savings $2 to $19.
9006XV XtraVision: The brighter light for upgraded performance. Up to 30% brighter light and up to 25% more downroad visibility.
9006CB Cool Blue: The whiter light for style. Up to 25% brighter light and up to 25% more downroad visibility.
License plate
168
Back up light
921
921ST SilverStar: The brighter, whiter signal light. Up to 30% brighter light, up to 20% whiter light and up to 10% farther and wider.
921LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Front sidemarker
168
Rear sidemarker
194
194LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Glove box
74
74LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Dome light
DE3175
DE3175LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Step/Courtesy light
2825
2825LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Trunk/Cargo area
DE3022
DE3022LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
The following 2 users liked this post by Adamjeeps:
Melissa8 (12-06-17), Planner (12-14-23)
Old 08-31-10, 08:36 AM
mandyfig
mandyfig's Avatar
Tail is regular bulb, STOP light is LED. At least on my RX330. I tore that Assy apart.
Old 08-31-10, 09:42 AM
ycl1688
ycl1688's Avatar
high mounted stop light is LED, what would you do to replace the bulbs on the stripe, could you clarify a bit ?
Old 08-31-10, 01:53 PM
mandyfig
mandyfig's Avatar
High mount stop lamp is LED.
Your brake light is LED on the tail.
However your Park Lights in your tail is regular bulb.
Old 08-31-10, 01:55 PM
mandyfig
mandyfig's Avatar
Learned the hard way. Had a stop lamp issue. Took the tail off thinking it was just a bulb replacement. There was a circuit board for the LED and couple of small bulbs for the park-tail light.
Dealer replaced the assemby on warranty.
Old 12-16-13, 02:04 PM
Mymaxl
Mymaxl's Avatar
Have a 350es lexus, left low beam went out, how do i change the bulb( turns and has a magnifier in front of the turning assy) help i bough a bulb, it has 2 contacts, but when i removed the wire to it it only has one contact,
Also, can anyone tell me where the fuse is?
Old 12-16-13, 03:59 PM
jakenbake
jakenbake's Avatar
The high beams are wired in series for the daytime running lights. That is what makes them dimmer during the day. Because of this, if one goes out they both go out....Just like christmas lights. When you flash or turn on the highbeams (not DRL) a relay switches the wiring so that they are independent instead of in series. So if you are basing the fact that they both burnt out at the same time by looking at the running lights, then it is normal. I always replace both bulbs at once...Otherwise they will be different colors and the second bulb always burns out soon after. The instructions are in the owners manual.
Old 12-19-13, 10:41 PM
Saltynutz
Saltynutz's Avatar
High beams are halogen bulbs, they could have made a mistake and giving you hid low beams estimates instead.
Old 12-20-13, 09:10 AM
jakenbake
jakenbake's Avatar
If you are a handy person...You can change the HID bulbs yourself. They are about 50 bucks for a pair of bulbs on ebay or amazon. They take D2S bulbs. It took me about 10 minutes to change the bulbs when I swapped out the 4300K HID for 6000K. I wanted to have a bit more of a BMW colored bulb.
Quick Reply: RX400h 2006 Headlight replacement
