Tire pressure indicator light
Old 08-29-10, 07:57 AM
campc
campc's Avatar
Default Tire pressure indicator light
I had a flat a couple of weeks ago and changed to the spare tire. The light came on and stayed on the entire time the spare was on the vehicle. Should have checked the tire pressure on the spare but did not.
The flat needed to be replaced and that took several days to get the new tire, mounted, etc. Now the matching tire is back on the vehicle.
The light went off when my husband replaced the tire, so we thought all was well. It stayed off for several days.
The light is now back on again. We've checked tire pressures on all 5 tires (4 on the vehicle plus the spare). All very close to 30 psi.
Any ideas on what could be wrong? Only other thing I can think of is to stop by the tire store -
Thanks.
2008 RX350
Old 08-29-10, 09:15 AM
pauljcl
pauljcl's Avatar
Thanks.
2008 RX350
I don't have the manual with me, but there is a procedure described therein to 'reset' the tire pressure monitoring system. Maybe you should try that ?
Old 08-29-10, 10:20 AM
campc
campc's Avatar
Yes - I should have mentioned that. I have used the procedure 3 times to no avail.
Might be a trip to the dealer in my future.....
Old 08-29-10, 12:42 PM
Rainbird
Rainbird's Avatar
I always inflate the spare tire to 38 psi. You will eliminate it as the possible cause by doing that. If the spare is needed you can deflate it to the proper psi.
Old 08-30-10, 07:26 AM
lexus114
lexus114's Avatar
38! ?? I`d hate to ride with you.
Old 08-30-10, 07:39 AM
salimshah
salimshah's Avatar
38 in the spare should be ok.
Salim
Old 08-30-10, 08:22 AM
Rainbird
Rainbird's Avatar
Nine times of ten when the tire pressure warning light comes on the culprit is the spare tire. I inflate the SPARE to 38psi and forget about it. The tires that I ride on are inflated to the Manufactures recommended pressure.
Old 08-30-10, 08:54 AM
lexus114
lexus114's Avatar
Ooooooooooo, ok. My Bad. I read that wrong. I thought you were putting 38lbs. in your tires all around.
Old 09-01-10, 12:32 PM
Asakura58
Asakura58's Avatar
noob Qes: I just my tire pressure monitors/sensors in the mail right now..CaN i get them installed anywhere else besides a lexus dealer? Can they make my light go away+make theses 2nd set? (for is)
thx
Old 09-01-10, 05:29 PM
Asakura58
Asakura58's Avatar
anyone with input? :S
Old 09-01-10, 10:57 PM
pauljcl
pauljcl's Avatar
thx
My understanding is that on the RXs previous to 2010, you can have two sets of TPMS with your system. 2010 only allows one set. The manual (again: I don't have it with me) - if I remember correctly - explains this as well as the procedure(s) to follow. I would assume a dealer would know too, as well as a number of tire dealers' places.
I would believe that - subject to the connection with your TMPS system - any reputable tire dealer's place can install them. Give them a call (?) or maybe speak to the people at tirerack.com?
Old 09-01-10, 11:18 PM
Asakura58
Asakura58's Avatar
lol it is actually for my is250, was too lazy to make another thread in IS section so though I would ask here. I guess I'll call up a tire place and ask tomorrow. thanks for the reply though
Old 09-02-10, 08:10 AM
Jonrx350
Jonrx350's Avatar
if the spare is low in PSI. It can trigger the light on the dash. Happened to me.
Old 09-07-10, 07:59 AM
mandyfig
mandyfig's Avatar
In 2004's the spare has no impact since the pressure is approximated via a sensor on the wheel/rpm.
Old 09-07-10, 02:40 PM
kickin8
2IS/2RX/4RX
kickin8's Avatar
thanks for the info..I didnt know the spare has a sensor....
Quick Reply: Tire pressure indicator light
