Brake pads and rotors
My wife just called from the Lexus dealer. We noticed a shudder in the steering wheel while braking (especially at highway speeds) and took it in. Diagnosis and pricing are crazy. Front pads have 7mm, front rotors slightly warped ("not a safety concern"). Rear pads 2mm. $700 per axle for pads and rotors. That is highway robbery, so I'll be calling the local Toyota dealer, and Meineke.
The car has just 40k on it, and since we bought it used with 26k, I suspect that the front pads were replaced already, otherwise the F-R wear makes no sense. Does the RX normally require new rotors with every pad change? My old Volvo did. I don't really want to leave the warped rotors on, and can pay the small extra for new pads in front, but I'd rather not replace the rear rotors if it isn't needed. What's the official position on the rotors?
Get the Lexus pads yourself, have the rotors turned. Install. Torque it right and pat your back. But if you are not the DIY type, have it done by Toyota. Would cost you not even half of Lexus quote.
Pads are $60 for front and $60 for rear. $ 120.00. Rotors turned for $10 a set, $20.00.
Labor, 4 hours total @ $50, $ 200. Total $340 out the door.
No, I don't play soccer!
My dealer replaced the rotors with the brake pads twice on my '04. First time at 16K was free because the rotors were defective, something about inferior metal. The second time around 44K, I only paid for the brake pads and labor. The service manager who was the service advisor when I had them changed the first time didn't charge me for the rotors after I complained a little.
Now I do mostly city driving, stop and go, so that may explain the wear on mine. If the rear brakes are original, I'd say you got a decent amount out of them. But it shouldn't cost you $700 per axle. Definitely go to a Toyota dealer. Good luck.
i can not see how rear rotor warpage would cause steering shutter. I can see the fronts. Rotors usually warp because of temperature shocks ie carwash, Going through water with hot rotors etc. Rear rotors usually do not get that hot to warp.
I'm nervous about the DIY aspect, since a brake mistake is life threatening. I did a lot of work on my Volvo S60, but I don't have a decent jack. If Toyota comes in at a decent price, I'll go there. Otherwise I may be going the DIY route.
I have over 75K miles on my RX330 driven a mixture of city and highway driving. The front pads were replaced at 40K miles. Rears have yet to be replaced, however, they are due as they are now down to 3mm. Rotors have yet to be turned and still provide a smooth braking experience. Will not be turned when I do put the new brakes on the rear and perhaps not even when it comes time for the fronts, again.
Now, granted I live in the flatlands. Still, sounds like either the previous owner or yourselves are hard on the brakes.
Once the rotors are turned they will warp quicker than previous as they would be thinner. Thus, the reason for replacing over turning.
True on the turned rotors. One turn, then replace. That would actually be ~ 80K for the one set of rotor, not bad.
Torque is a key ingredient in all this. Lug Nuts must be torque'd @ 80 ft-lbs.
Just did my rear pads. Got 75k out of them. Got the lifetime Duralast semi-metallic from Autozone for $20 a set. Rotors looked good so I did not bother to have them turned. So far so good, the pads are seating nicely!
I would only use the Toyota pads for our Lexus, just me.
I have used Durlast in the past on multiple cars front and back semi-metallic and ceramic with no problem. I choose them because of there lifetime no questions asked replacement warranty. Since my driving style is kind of hard I usually warp out the front rotors before the pads are gone, either using stock rotors and pads or after market pads on stock rotors or aftermarket rotors with aftermarket pads. I figure why waste more money on stock pads when I never get to the point of using them up because I have to change rotors or have then turned. In the long run it saves me money because I don't have to buy a new set of pads every time I have to do rotor work.
