Bleeding procedure on 2006 Rx400h
I have the service manual for my 400h and the only procedure it shows is hooking up the diagnostic computer and cycling the electric pump. Are you sure a bleed kit hooked up to the master reservoir will work? What if this return path also needs the electric motor to allow the fluid to return?
Reverse pumping to un-brake (if there is such a term) is very very unlikely. I am always ready to learn new things. If you find something please share.
Please do not misunderstand me .. controlling the pressurized path(s) and getting the boost is a sure way to bleed. The pumps can also suffer from air-locks. [see my earlier post in the same thread].
Since it is hard to lay your hands on some of the equipment available at the dealership, I am merely pointing out the alternatives that exist.
Salim
Oh, I'd like to know of alternative that work as well, since replacing brake fluid is something I've always done myself. I'd love to do it myself on the RX400h, but as I said the service manual only shows the one way (Lexus diagnostic computer - using electric pump).
I have also read of others that have tried to bleed the RX400h in the traditional way and ended up with spongy pedal and numerous warning lights on the dash, necessitating a visit to the dealer to have the system bled properly.
I found this in my service manual...
"During normal braking, the fluid pressure generated by the master cylinder does not directly actuate the wheel cylinders, but serves as a hydraulic pressure signal. Instead the actual control pressure is obtained by regulating the fluid pressure of the hydraulic power source in the brake actuator, which actuates the wheel cylinders."
So my guess, based on this, is that pressurizing the master cylinder will NOT bleed the brakes on the RX400h. You must instead somehow power the brake actuator, which will pressurize the line to the wheel cylinder and force the brake fluid out.
This is where the service manual procedure for bleeding the brakes on the RX400h instructs one to hook up the Lexus diagnostic computer and cycle the brake actuator.
The brake actuator is located close to the master cylinder but actually right against the passenger fender wall, with hydraulic lines in from the master cylinder and out (to the wheel cylinders I guess. It's a metal box (cube) with a couple of electric motors hanging off the front.
I was wondering if turning the ignition on which is kind of scarey would make the electric pump work normally...? Maybe if the car is up on stands and the engine is running you could bleed the system...I will look at the schematic on the brake electrical and see if there is a way to turn the pump on...manually.
In a non-hybrid car, the brakes and the steering can still function when the engine is off.
Therefore the brakes and steering still work in case of emergency (ie. running out of gas at 65 mph LOL ).
On a hybrid, do the brakes and steering still work in an emergency situation where the engine and batteries are dead ?
the engine is not necessary, but the batteries would have to function if you are applying brakes, the hybrid uses electric pumps for pressure... Note I looked at the schematics, and am at a loss to turn the pump on. The intelligent tester to the DLC3 connection is there, but it goes into a mini computer circuit board... still wonder if turning the ignition on will work.?
This is my experience on GS (which has an electric pump).
On depressing pedal, one rear slave bleeds out the fluid. When it bleeds it does not stop. [the non-electrical-pump only lets out the fluid that is compressed by the pedal]. The other side does not bleed. [This is where an over-ride for ABS is needed].
As soon as I find information for the external pump .. I will post the link. These pumps push the fluid down the master cylinder (expecting the return path to be open ... no brake applied).
Ok here it is
http://www.apexperformance.net/cartg...FcW8KgodBQOybw
I am not endorsing the merchant.
Salim
Ok here it is
Salim
Ok here it is
Salim
Ok here it is
Salim
If it's as easy as pumping the brakes with the ignition on, why would the service manual have instructions to hook up the diagnostic computer? Are they just trying to force ppl to take their vehicle to the dealer?
Will this work though, since the fluid in the master cylinder is only used as a pressure signal to the brake actuator, or are you suggesting to use this with the ignition on, so that the pressure from the external pump activates the actuator, and no need to step on the brake pedal?
The diagnostic computer would open all channels (path to all 4 slave) and would require pressure on the brake pedal to activate the electrical pump. [the diagnostic computer may even have a button to turn on the pump ... I am guessing as it is dealer item]
The other option is to use the pressure pump (link). This would work with vehicle turned off and no one pressing the brake pedal. With the brake pedal in released position (not depressed) the slave cylinders have a free path back to the reservoir. The pressure pump then pushes the fluid down the master cylinder to the salve. You bleed one at a time. You need an adapter to the master cylinder.
If you go the web-site of the pressure pump, they have a better explanation.
Salim
I was almost going to buy one .. needed to bleed the clutch on son's bmw .. the pedal does not return by spring action .. you pump down and then pull up . Since it was a single destination point, I just let gravity bleed it.
Salim
ps: I was also tempted to make a universal pump with a latex glove as an adater to any master cylinder reservoir and was looking for a cheap bellows type stoking pump connected to the finger. I am on the look out for that trinket every time I accompany my wife to the Asian Import stores.
HF also sells a suction/pump device which you connect to the bleed end. Dont know how good it is.
Salim
Mini VCI
Lots of people like this Scanning device. They say it allows you to everything the factory computer does. I bought it with the hopes of bleeding my brakes using the internal pump/factory method.
Fotga mini VCI
I have Star Diagnostic and use it for everything on Mercedes Benz (including brake bleeds), but that costed me around $600. If the Fotga would allow me to only bleed my brakes on the Lexus, I would gladly spend the $24. I haven't attempted to use it yet so do your own thorough research before jumping in. I hear most people run it on Windows XP 32 bit laptops. Most people aren't still using that OS, but one individual said he got it to work on Windows 7 64 bit.
