Rear floor latches 2006 rx330
Old 05-28-10, 06:20 AM
relax221
relax221's Avatar
Default Rear floor latches 2006 rx330
My rear floor compartment floor won,t lock the floor down. One latch on each side and stick in the retracted position and wont release to lock the floor boards. I pryed and sprayed with wd 40 no luck...
Any help fellas ?
Mike
Old 05-28-10, 03:03 PM
kiwi
kiwi's Avatar
sounds like you may have popped a spring,
it jsut so happens that i installed my hitch today, so i am very familiar taking apart the rear floor area.
step 1 pop open the two compartments (you dont have to worry about this.
step 2, there are little clips which just pop off, (pull them up) perhaps with a screw driver.
step 3, the large tray comes out first, just pull it up,
step 4 pop off the trim peice which contains the release buttons,
this should give you a good look at those releasers.
hope that helps
Old 10-05-12, 11:18 AM
Bhappy
Bhappy's Avatar
Having the same problem. So it may be a bad spring?
Old 05-23-14, 07:31 AM
HalRX300
HalRX300's Avatar
Question RX330 rear compartment latch stuck retracted
My RX330 rear compartment latch stuck retracted.
Did anyone ever find a solution for this?
Thanks,
Hal
Old 09-03-17, 10:18 AM
mikecd1
mikecd1's Avatar
The part number near as I can tell is
584050E010
Not sure why they go bad, but I got my car used and both did not work.
batchelor
NX 200t / 300h Classifieds
01-04-18 11:33 AM
2GR
12-31-16 12:22 PM
kickin8
08-17-11 01:27 PM
krawfo
02-09-10 02:07 PM
excluesive
04-13-08 03:58 PM
Quick Reply: Rear floor latches 2006 rx330
