how to remove maf sensor for rx330 ?
Old 05-24-10, 06:37 AM
ycl1688
ycl1688's Avatar
Default how to remove maf sensor for rx330 ?
trying to clean maf sensor, how to remove it ?
Old 05-24-10, 07:19 AM
lexus114
lexus114's Avatar
its simple,just take out the two small screws,(disconnect the wiring first) and it pulls right out. only clean it with maf sensor cleaner !!
Old 05-24-10, 07:25 AM
ycl1688
ycl1688's Avatar
By the way how is your air filter cover did it fully cover the air filter element, because mine could not fully covered, at the left side of the cover there are two plastic lips that are stopping the cover from fully closed, could you shed some lights ?
Old 05-24-10, 07:28 AM
ycl1688
ycl1688's Avatar
there seems a plastic clip that has to be taken care of before the wiring can be disconnected ?
Old 05-24-10, 07:30 AM
lexus114
lexus114's Avatar
correct, i think you push down on it.
Old 05-24-10, 07:33 AM
lexus114
lexus114's Avatar
its got to fit correctly,or your going to have a problem. try sliding the tabs in the little spaces.
Old 05-24-10, 07:50 AM
ycl1688
ycl1688's Avatar
you mean try to slide the tabs on the cover (left side) under the bottom ledge of the housing (lower body), is it correct ?
Old 05-24-10, 07:52 AM
lexus114
lexus114's Avatar
im trying to remember how this looks,but yes you do the left side first like you mentioned.
hypervish
RX - 1st Gen (1999-2003)
43
12-27-18 01:30 PM
kenkadish
05-04-16 05:06 AM
Harold57
07-06-11 01:17 PM
Neil64
03-30-06 09:06 PM
SupraSpd4u
SC400 / 300 Classifieds
02-10-06 09:04 PM
Quick Reply: how to remove maf sensor for rx330 ?
