would you go for aftermarket cabin filter and air filter ?
Old 05-11-10, 09:11 AM
ycl1688
ycl1688's Avatar
Default would you go for aftermarket cabin filter and air filter ?
How good is rx330 aftermarket cabin and engine filters vs toyota filters ? Price is lot different ? what else ?
Old 05-11-10, 09:25 AM
salimshah
salimshah's Avatar
Cabin filter:
Make sure the after market has activated charcoal. Then compare price difference. Any affect of restrictive flow or letting larger particles go through will appear over long time. Worst scenario, is blower motor going bad, or accumulation of dirt in the duct.
Engine air and oil:
This is more complex and you will have to do the home work to make sure you are getting at least the same or better. Watch out for the "for-ever" air filters as they work with oil, which causes problems for air flow sensor.
Salim
Old 05-11-10, 09:45 AM
Grumpa72
Grumpa72's Avatar
I have no complaints with the aftermarket cabin filter that I got from Advance Auto. Fit is nice and it does filter well.
Oil filters are another thing. Here is a link to an updated study by one very curious guy. It is a redo of an older filter study.
http://minimopar.knizefamily.net/oilfilters/index.html
I started reading about oil filters when I bought my first mid to high end car and wanted to ensure that I got the best I could for engine protection. The link is descriptive telling you how he studied them. You can click on one of the hot points to go to the study itself. Fwiw, I use Wix filters from NAPA which have a very good reputation both for modern applications and also for a classic car that I have that sees limited use.
I have no burning need to use OEM oil filters since the auto manufacturer doesn't make them but subcontracts them with a specified set of engineering requirements. It is my assumption that some/most/many? aftermarket oil filter manufacturers try to get as close to the OEM specs as possible while trying to keep costs down. It is not my intention to buy the cheapest oil filter but to buy the one that does the job well. Again, look at the study, find a filter that meets your needs and have fun.
Here is a link from one of the hot links showing some good information. Danger Will Robinson! Danger! Ok, sorry for the REALLY old TV spot but, before you flame me, I recognize that this is an old post but I believe that the data is still relevant.
Old 05-11-10, 10:04 AM
salimshah
salimshah's Avatar
Your question is about Rx300 and it is posted in RX350.
You can have the mods move it.
Salim
Old 05-11-10, 10:30 AM
Grumpa72
Grumpa72's Avatar
Salim
Regardless of the year, OEM versus aftermarket filters is relevant across the vehicle spectrum, don't you think?
Old 05-11-10, 11:04 AM
ycl1688
ycl1688's Avatar
Salim
should be rx330, sorry.
Old 05-13-10, 07:49 AM
LBCDan
LBCDan's Avatar
Default Go with DENSO
DENSO makes the OE cabin air filter so go with that one. It has charcoal on one side to absorb odor.
Old 05-14-10, 08:41 AM
mandyfig
mandyfig's Avatar
Decent aftermarket filters, are equal to or better than OEM's. Sometimes, the aftermarket ones are the OEM makers pf the "OEM" parts.
I say "decent", to me is Purolator One Premium, nothing else for the RX. So if I can buy the Denso OEM for a cheaper price, I am all over it.
You get Purolator One on sale and some rebates, I am all over it.
Old 05-14-10, 03:07 PM
Lexmex
Super Moderator
Lexmex's Avatar
One common thing people used to do with the first generation RX many years ago was go buy the furnace filters (and/or material) at Home Depot and make their own.
Old 05-15-10, 07:36 AM
xfirechief
xfirechief's Avatar
Why?
They only cost around $15.
Old 05-16-10, 06:55 AM
cmichael
cmichael's Avatar
Has anyone ever purchased and used the TYC brand of cabin filters?
Old 05-17-10, 02:06 PM
metal
metal's Avatar
Easy answer...yes, they work fine and for a lot less $
Old 05-17-10, 11:23 PM
howdybob22
howdybob22's Avatar
To answer the OP original question, yes if they fit like OEM and well made.
rd400racer
07-10-19 03:44 AM
joedr
IS F (2008-2014)
10-10-18 08:18 PM
LexChamp
27
08-19-10 08:44 AM
aznking
IS F (2008-2014)
07-15-10 07:51 AM
moolman
09-06-09 11:35 AM
Quick Reply: would you go for aftermarket cabin filter and air filter ?
