Sunroof power open/close
Old 03-28-10, 04:10 PM
emi
emi's Avatar
Default Sunroof power open/close SOLVED
Hi all.... So I just realized that my sunroof/moonroof no longer opens automatically when I press the buttons.. either the tilt nor the other button.... I have a 2006 400h... I know the dealer programmed it to open and close without holding the button... Does anyone know how I can re-do it? I don't even know why it stopped working! Thanks...
Old 03-28-10, 04:36 PM
jfelbab
jfelbab's Avatar
Push the open switch and hold it while the roof opens, closes, tilts up and tilts down. Then release the button and it will be re-programmed.
Old 03-28-10, 04:51 PM
emi
emi's Avatar
thanks a lot Jim.. will try tomorrow..
Old 03-28-10, 05:08 PM
kitlz
No, I don't play soccer!
kitlz's Avatar
Check the battery too. Auto open/close stops working when the battery is starting to go.
Old 03-29-10, 01:28 PM
emi
emi's Avatar
Not something I need to worry about right now Anita.. lol...
Old 03-29-10, 01:37 PM
mandyfig
mandyfig's Avatar
You are re-initializing. Same thing happens with your windows and power gate. You probably unhooked the battery recently, hence you lost the program.
Old 03-29-10, 03:13 PM
kitlz
kitlz's Avatar
emi, I hope it's as simple as re-initializing. I've had my battery disconnected for hours while stereo work was being done but didn't lose the auto open/close function. It's only when the battery started to go that I did. It was covered under warranty. Good luck.
Old 03-29-10, 03:15 PM
emi
emi's Avatar
Default ?
How long is the warranty on the battery??? Mine is an '06!!! Any idea how much batteries are?
Cuz in all seriousness, I haven't had any work done on it! so the battery hasn't been disconnected!
Old 03-29-10, 03:34 PM
Maverick16
Maverick16's Avatar
I just bought a new 2 year battery, it cost me about 60 bucks.
Old 03-29-10, 04:37 PM
kitlz
kitlz's Avatar
emi, you should be ok. It's still under warranty. Mine went at 4 1/2 years but I blame the extra stereo equipment
Old 03-29-10, 06:37 PM
mandyfig
mandyfig's Avatar
Battery is 84 month warranty, look at the label, I have it on mine.
Old 03-30-10, 06:26 AM
lexus114
lexus114's Avatar
Yep,I just recently went through this process with my sunroof. Its in the manual how to re-program everything.
Old 04-03-10, 07:04 AM
emi
emi's Avatar
thank you all... it worked! now will have to get the battery checked...
Bombsquad
03-01-21 12:09 PM
tomr51
09-25-17 01:02 PM
Mr.Doback
05-05-15 12:27 PM
IXI187IXI
02-28-11 05:45 AM
jtbmoore
GX - 1st Gen (2004-2009)
12-21-05 03:35 PM
Quick Reply: Sunroof power open/close
