Seatbelt and Remote lock no sound
Old 01-31-10, 01:12 PM
doverrx330
doverrx330's Avatar
Cool Seatbelt and Remote lock no sound
I purchased a pre-owned RX330. When you are sitting in the seat, the seatbelt icon flashes on the dashboard but doesn't make a sound to remind you to put it on. Also, when you use the remote to lock the vehicle the horn doesn't sound to let you know its locked. How do i get both of these functions to make noises?
Old 01-31-10, 02:13 PM
rcy
rcy's Avatar
Here's how to turn the seat belt chime off, so do the same procedure and it should turn on. Regarding the beep when you lock the car - dunno, maybe it's a dealer changed option (and it's not the horn that beeps but some small chimie in the driver's side fender area.
1. Sit in the driver’s seat with the key in the “ON” position. Using the “display” button on the steering wheel, rotate through the displays until the LCD on the gauge cluster is only reading the mileage, not trip A or B, just the mileage.
2. Turn the car off and pull out the keys. Open the driver’s door and close it again. Put the keys back into the ignition and put it to the “on” position again. As soon as the LCD display on the gauge cluster goes from “hybrid drive” back to the mileage, begin to hold down the “trip reset” button to the left of the steering column for approx 30 seconds.
While still holding down this button, (it may be tricky) pull down the seatbelt and buckle it. At this point look at the LCD display on the gauge cluster. You may let go of the “trip reset” button at this point. The display will now read “seatbelt buzzer ON”.
Press the “trip reset” button once and the display should change to “seatbelt buzzer OFF”. You’ve done it! You can turn the car off, as the setting is now changed and will remain this way until you change your battery again, or repeat the steps to change the setting yourself.
Old 02-01-10, 06:36 AM
draco
draco's Avatar
How does one do this on a "non-Hybrid" RX330 or even a 350? Same procedure or is there another option other than "hybrid drive" that allows this to be done?
Old 02-01-10, 12:45 PM
xfirechief
xfirechief's Avatar
Keep It Activated. Seat Belts WORK
cmotomn
10-19-23 11:25 AM
njes300
08-26-16 02:27 PM
USCRugby
03-09-08 03:47 PM
Scrappy
08-22-07 01:37 AM
PaJaHa1
ES - 5th Gen (2007-2012)
11-15-06 09:49 AM
Quick Reply: Seatbelt and Remote lock no sound
