90,000 Service
Old 01-06-10, 10:12 AM
keycard198
keycard198's Avatar
Default 90,000 Service
My Lexus RX330 2004 is heading towards the 90,000K service area--what price should I be expecting? I bought this car used with around 75K where they changed the cabin and air filters already. And I believe that the 90K also has that items on the list..can I tell service to not change those and get a discount?
And I also got a Platinum Warranty for 5 years---which covers the water pump. In That case--do I need to change it since it is covered?
Thanks!
KC
Old 01-06-10, 11:30 AM
RJLEXUS96
RJLEXUS96's Avatar
Each Lexus dealer prices the services different. The main things to replace at that mileage are:
Oil/Filter
a/c filter
air filter
brake fluid, alogn with all the inspections etc... should run you around $450.
But some dealers add or subtract certain items from that list.
Old 01-06-10, 01:46 PM
Iqraam
Iqraam's Avatar
Well i have been lookin into this service as well. Each dealer is a little different however the services should be the same. There are two service due at this mileage.
1st-All the fun stuff-timing belt, drive belts and plugs and water pump.
2nd-All the fluids and filters are changed and inspections etc.
Lexus Dealer-$1700
Toyota Dealer-$1200
I live in California so things are more expensive around here but as you can see the significant difference in price between the two. Expect to pay that much to do a quality 90k service.
Quite frankly after this service the car is practically like brand new.
Old 01-06-10, 02:02 PM
mandyfig
mandyfig's Avatar
Thanks!
KC
Warranty will not replace any component that has not broken down. You really do not want to be stranded with a failed water pump.
The water pump will not fail until 120K+ miles. Will your car still be covered with extended warranty then?
Get it done on 110K miles. Good luck.
Old 01-06-10, 02:05 PM
mandyfig
mandyfig's Avatar
90k is not a scheduled major tune up. 100k+ is. I have to check my manual.
Checked the manual and yes indeed, 90K is the major tune up which specifies the timing belt be replaced.
I have heard many times that Toyota timing belt is good for 100K. I will probably wait for 100K to do mine. Maybe when it comes, I would have the guts to do a DIY!
Old 01-06-10, 06:57 PM
keycard198
keycard198's Avatar
The Platinum Lexus Warranty should last me till 130,000 miles...
Old 01-06-10, 09:23 PM
mmlex1987
mmlex1987's Avatar
Oil/Filter
a/c filter
air filter
$450.00 seems like/is so much $$$ for just these couple items.
Old 01-07-10, 07:45 AM
mandyfig
mandyfig's Avatar
Minus the inspections which you can do easily:
DIY
Oil and Filter change $6 + 5 x $5.00 = $31.00.
AC Filter $20
Air Filter $15
Drain, purge, $15.00
3 hours of DIY. $81 in material. @ $80/hr that's only $240 + $81. Are you worth $80 per hour?
Old 01-10-10, 07:30 AM
hesham1
hesham1's Avatar
dont forget the cabin filters on ebay are around $12 shipped if you dont mind an aftermarket one
Old 01-11-10, 07:10 AM
lexus114
lexus114's Avatar
My Lexus dealer wanted $504.00 for the 90k service. So I did everything myself,except I took it to my mechanic friend to do the transfer case/rear diff. Glad i did,he had to heat up the rear fill plug to get it out. OOP`s,I SCREWED UP! that was for a 60k service not the 90. probably almost the same anyway though.
Old 01-11-10, 07:14 AM
mandyfig
mandyfig's Avatar
The above includes timing belt change?
Old 01-11-10, 07:18 AM
lexus114
lexus114's Avatar
No,I messed up. It is for the 60k service. The timing belt will easily go 120k. So that is the least of my worries.
Old 03-18-11, 05:13 AM
JamesHuang
JamesHuang's Avatar
Or from Sewell who's a CL forum vendor
Old 03-18-11, 06:43 AM
jfelbab
jfelbab's Avatar
So your dealer wanted $504 for the 60k service?
My Lexus dealer charged me $364 for that service and I got a new RX as a loaner. I'd be checking prices at other dealers.
Old 03-18-11, 07:58 AM
diverchris
diverchris's Avatar
I'm getting the service done today. I purchased all of the parts so I did not have to pay retail. I spend $611 on the following parts:
drive belts
timing belt
water pump
idler assembly
all new gaskets
So the bill will be for labour only
Chris
Quick Reply: 90,000 Service
