2005 RX 330 Rear Window Control
Old 12-21-09, 07:02 AM
KM1759
KM1759's Avatar
Question 2005 RX 330 Rear Window Control
I realized yesterday that I can no longer control the driver's side rear window from the driver's switch. It works fine from the switch on the rear door. All other windows work perfectly. Also, the auto down feature (by holding the unlock button) does not lower that window. Although the battery has not been connected (and is pretty new) I did the reset procedure, just for good measure, to no avail.
Any thoughts would be appreciated.
Old 12-21-09, 11:18 AM
kitlz
No, I don't play soccer!
kitlz's Avatar
I had a similar problem when I picked up my 04. The rear driver's side window did not work at all. The receipt says they replaced the passenger rear window switch. I'm sure someone here can provide a little more insight and tell you where to pick one up cheap. Good luck.
drgerry
07-03-17 12:22 PM
juancontre
08-31-13 12:10 PM
Leines
RX - 1st Gen (1999-2003)
12-25-12 08:13 AM
gleqx
12-10-12 05:47 PM
tianh
04-11-12 07:32 AM
Quick Reply: 2005 RX 330 Rear Window Control
