Go Back   Club Lexus Forums > Lexus Model Forums > RX Models > RX - Second Generation
Thread Tools Display Modes
Old 10-17-09, 09:59 PM   #1
robins117
Trader Score: (0)
Default tire selection
I have a 2008 RX350 with 26K on the OE Goodyear tires. I researched CS and TireRack and saw that the Kumho Road Venture had good reviews on both. I put those on and they have so much vibration. I took them back and they "road force" balanced and now they're worse. Has anyone experienced anything similar? The retailer (Kauffman Tire) offered to replace them with another tire. They're recommending the Toyo Versado LX or Open Country H/T. Does anyone have any info or experience with either of these Toyo's? I live in the southeast, so snow is really not a concern. I just joined this forum and I've seen some posts about the Bridgestone Dueler Alenza. I'm not sure if I'll be able to swap for those now, though. I'd like to find tires that ride well, have good wet traction and will last at least 40K miles. Would like some recommendations.
robins117 is offline   Reply With Quote
Old 10-18-09, 08:15 AM   #2
jfelbab
2004 Lexus RX
My Garage
Trader Score: (0)
jfelbab's Avatar
I own the Bridgestone Alenza's and the ride and feel are much better than the OEM Goodyears. If I were to purchase again it would either be another set of the Alenzas or the Yokohama PARADA Spec-X.
That said, there are no reviews that I have found that suggests the Road Venture has a lot of vibration. I wonder if there is not some other issue. Perhaps a defective tire belt or a problem with the balancer.
__________________
Jim
"Funky Monkey goes Gold"...Top played tune at MacIdol.com for over 66 months.
Listen to my music here.
jfelbab is offline   Reply With Quote
Old 10-18-09, 08:48 AM   #3
kitlz
Trader Score: (0)
kitlz's Avatar
I just replaced the Bridgestone Alenzas after 33K on my 04 with the Michelin Energy MXV4. So far so good, the ride is nice and tight again and much better than the Goodyears on it originally. Michelin also has a $70 rebate available when you buy four.
__________________
Anita
2010 RX450h - pending
2004 RX330 - Nav/Performance
1999 RX300 - Traded in
With quality you only cry once!
kitlz is offline   Reply With Quote
Old 10-18-09, 09:38 AM   #4
kiwi
Trader Score: (0)
Quote:
apparantly they were road force balanced, which rules out/finds any tire problem whatsoever, so it wasnt a defective tire
kiwi is offline   Reply With Quote
Old 10-18-09, 03:14 PM   #5
srm47
Trader Score: (0)
I have about 4000 miles on a set of the Bridgestones H/T's on a 2008 RX 350 and couldn't be happier. They replaced the crap Goodyears that barely made it to 30K miles. I run the Bridgestone's at 32-33 PSI and the ride is great without losing much on the handling side.
srm47 is offline   Reply With Quote
Old 10-19-09, 08:33 PM   #6
Grumpa72
Trader Score: (0)
I put Bridgestone Dueler Alenzas on my 05 and I LOVE them. The OEM Michelins were quite good and went about 48K+ on the them. When I went to look at them as replacements, they did NOT have a warranty. The Bridgestones do and they ride wonderfully - low noise, no vibration and, after about 6000 miles, no appreciable wear. They will be my next tire too.
Grumpa72 is offline   Reply With Quote
Old 10-20-09, 12:07 PM   #7
robins117
Trader Score: (0)
Thanks for the feedback. I should have checked on the forum first. I'll see if I can get the Bridgestone's but I don't think this dealer carries Bridgestone. I'll have to see what my options are. Could be that I'll need to choose a Toyo, Goodyear or Michelin (they carry those) and if that's the case, I'll probably end up going with the Toyo Versado. If that doesn't work, I'll have to see if they'll give me a refund, but kind of doubtful.
Old 10-20-09, 01:01 PM   #8
kitlz
Trader Score: (0)
kitlz's Avatar
My dealer doesn't carry the Alenzas either. In the past, I purchased them and other non-OE tires from my fav local tire store, put them in the back, and then drove down to the dealer to install and align. When I changed from the Alenzas to the OE Michelins last week, it turns out the dealer was actually cheaper than my local tire guy by a decent amount. And I had a coupon for a free alignment
You can't go wrong with the Alenzas. They were pretty decent. Michelin has always been great too. I don't know about the Toyos. I have to say I was surprised you got 26K on your Goodyears. Mine lasted only 16K.
__________________
Anita
Old 10-20-09, 07:56 PM   #9
jimp
Trader Score: (0)
I put on the versado lx 10k miles ago after getting 45k out of the original michelin they seem smoother and just as quite.no change in gas mileage.overall quite pleased and can find nothing to persuade me to switch to something else.
jimp is offline   Reply With Quote
Old 10-29-09, 05:02 PM   #10
DaveJ
Trader Score: (0)
DaveJ's Avatar
Here's another vote for the Bridgestone Dueler Alenza. Great tire for our RX330. Very happy with them. Very quiet, good handling, smooth, and wears nicely.
__________________
2005 RX330 AWD Neptune Blue, NAV
2009 Ford Escape Limited, FWD
Retired:
2006 GS300 AWD 49,900 Miles
2000 RX300 AWD 103K Miles
2000 Mercedes SLK320
1998 Mercedes E320
DaveJ is offline   Reply With Quote
Old 11-01-09, 10:16 PM   #11
skpsm
Trader Score: (0)
Quote:
Another vote from me for the alenzas. 20k+ and driving quiet and smooth
skpsm is offline   Reply With Quote
Old 11-03-09, 11:11 AM   #12
asianrage
Trader Score: (0)
My factory set of Michelin MXMV4 Energy lasted for 55K miles. I replaced those with a new set of Nitto NT420S sized at 255/55/18. Ultra High Performance All Season tires. 50 bucks cheaper but about 4lbs heavier, per tire, than the 235/55 sized Michelins. Ride very nice, though if I was to do it again, I think I might go back to the factory 235/55 sizing. I don't know how good treadwear will be, but I'm hoping that it'll be according to manufacturer's specs. I keep the tire pressure at around 31lbs.
asianrage is offline   Reply With Quote
Old 11-03-09, 11:14 AM   #13
asianrage
Trader Score: (0)
I was going to get the Kumho Venture, but i found that, for the size, according to TR.com, that it was too heavy. It would diminish the MPG too much for my liking. My Nittos are lighter, but being heaving than the Michelins, I did suffer a 1-2mpg drop. I can't imagine how low the MPG would be with the Kumhos.
Old 11-03-09, 11:42 AM   #14
lexus114
Trader Score: (0)
lexus114's Avatar
Quote:
I really like (besides Michelins) Falken tires.
__________________
lexus114 is offline   Reply With Quote
Old 11-06-09, 03:30 AM   #15
jmaynard
2008 AM General H1
My Garage
Trader Score: (0)
jmaynard's Avatar
My 2007 came with the Michelins from the factory. I got 51K out of them, and just replaced them with four more. I saw absolutely no reason to change a thing.
__________________
2007 RX350 AWD, Savannah Metallic/Ivory Leather, Premium Plus, nav system, XM - December 2006
Previous: 2001 RX300 AWD - November 2000
jmaynard is offline   Reply With Quote
Tags
backward, country, force, ht, installing, kauffman, open, parada, review, road, rx330, specx, tire, toyo, versado
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Go
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
Copyright © 2000-2008 Internet Brands, Inc. All Rights Reserved
Privacy Policy | Disclaimer | Terms of Use | JOBS
