RX330 / RX350 / RX400 : During your ownership what broke down?
Old 08-17-11, 09:28 AM
  #46
mandyfig
mandyfig's Avatar
Replaced on my RX:
1 Rear Tail
2 Side mirrors
4 Door handles
1 Grab bar (pass side)
Repairs:
Brake SW
AC Noise, damper
Warped Rotors
Master cylinder TSB
What else....
Old 08-17-11, 10:14 AM
  #47
Carver
Carver's Avatar
When I got my 330 at 73K I had to repair the stuff that had probably made the original owner trade it in the first place. The wholesaler I got it from had replaced the battery and a coil which was no doubt a prime motivator and the rear tires were cupped and sounded for all the world like both rear wheel bearings needed replacement. It also had a leaking steering rack and needed rear brakes.
It was just an '05 330 that needed some midlife love. I had salvaged the new tires and 18" wheels from my totaled RX300 so that solved the rear end noise. I took the bad rear brakes as an opportunity to replace all four rotors with new drilled ones combined with Akebono ceramic pads all around and installed a rebuilt factory rack.
We replaced all the fluids and aligned all four wheels and did a detail. All the TSBs are up to date. I've done quite a few mods but those are for fun and aren't part of breakage and maintenance.
Except for the flurry of repairs when I first got it there have been no other incidents.
Old 08-17-11, 10:48 AM
  #48
Nick318
Nick318's Avatar
Other than a lock actuator mechanism that I recently had to replace, it has been knocked on wood.
Old 08-18-11, 07:47 AM
  #49
gusar
gusar's Avatar
rear wheel hub, battery, did some brakes job (pads, re-surfacing)
Old 08-18-11, 07:52 AM
  #50
airahcaz
airahcaz's Avatar
so lots of issues with the 330's, but also with the 350's?
Old 08-18-11, 09:12 AM
  #51
mandyfig
mandyfig's Avatar
Overall been happy with the RX. Got the major repairs under TSB's and extended warranty took care of the rest.
Forbes lists Lexus' 3 cars on the top 10 (maybe even 4) most reliable cars in terms of repairs.
I saw LS460 (#1), ES350, GS350 on the list.
Old 08-18-11, 09:19 AM
  #52
airahcaz
airahcaz's Avatar
got a link to that article?
Old 08-18-11, 09:21 AM
  #53
rcy
rcy's Avatar
In addition to my earlier post in the thread, I have to add this one..
2006 RX400h, hybrid transaxle (err..we call it a transmission, Lexus calls it a transaxle) replaced at 155000 KM as it was leaking coolant. Roughly a $5000 part with labour on top of that. Fortunately for me, it was 100% covered under the extended warranty. My earlier post was the hybrid inverter, a $7000 part, also covered but under the Hybrid Warranty, not the extended warranty.
Old 08-18-11, 09:30 PM
  #54
LexusFamly
LexusFamly's Avatar
My 2007 RX 350 has been rick solid. Only issue that was non normal maintenance due to normal wear and tear (e.g. brake pads, tires, battery, etc) was having to change the rear hatchback motor and pistons. They were going up half way then would stop. Dealer lubricated for a few visits then replaced the parts listed under warranty. We are at 71,000 miles at the car has lived up to its reputation.
In fact, last Wednesday, just purchased a second Lexus; 2008 GX470.
Old 08-18-11, 09:39 PM
  #55
RX330inFL
RX330inFL's Avatar
Surprised nobody mentioned about their keys breaking. A constant topic in the threads about replacing keys. Had to have both of mine replaced even though I was very careful about where I hold the key.
Old 08-19-11, 02:55 PM
  #56
satz
satz's Avatar
forgot to add:
my 07 RX makes this 'rattling' noise for a second after starting the engine. Only happens if I leave the car parked for about 30 minutes when the engine's already hot.
Service Dept says it might have something to do with the VVTi, but 'not to worry' as it is not damaging anything
Old 08-20-11, 04:43 AM
  #57
biff44
biff44's Avatar
2 rear wheel bearings.
Old 10-06-11, 06:52 AM
  #58
jwoodwkr
jwoodwkr's Avatar
At 40,000 miles I begin to see moisture in my right headlight assembly. In my job, I travelled a lot and was too busy to take it in right away. I thought it would dry out during the summer. At 55,000 miles the low beam bulb shorted out; probably due to the moisture. Now the Lexus dealer is quoting me $1,000 to replace the entire assembly, because it is now out of warranty. $1,000 for replacing a burned out headlight is just unreasonable. It seems like this is a common problem that Lexus has failed to correct. Not what I expected from them.
Old 10-07-11, 05:11 PM
  #59
kelvinmac
kelvinmac's Avatar
my 2004 rx has 121,00 miles and i got it with 36,000 miles n the only problem i've had is the radiator had to be replaced
Old 10-07-11, 11:08 PM
  #60
LxRxKen
LxRxKen's Avatar
Originally Posted by T-Rex
Wife has an '05, and we just completed the 60k service @ dealer when the odometer showed 67k or so. Aside from common maintenance items and other smaller misc. things, we had to change out the steering rack @ $1200. Our local dealer never mentioned any internal Lexus "service campaign"? Could this be a Canda thing, or have others had issue with steering rack? It was suppose to be a small leak, but in order to fix it, they had to replace the whole rack. Fortunately, we have the extended warranty where it paid for most of it. Aside from that, it's been a good vehicle.
How do you know of the STEERING RACK is needing replacement?
Quick Reply: RX330 / RX350 / RX400 : During your ownership what broke down?
