Go Back   Club Lexus Forums > Lexus Model Forums > RX Models > RX - Second Generation
Thread Tools Display Modes
Old 06-24-09, 12:48 PM   #1
TvS
Trader Score: (0)
Default Cruising Range on 2008 RX 350
When cruising range indicates 0, how much gas is left in gas tank? I drove for over 15 miles when indicated 0 miles left.
TvS is offline   Reply With Quote
Old 06-24-09, 12:57 PM   #2
hesham1
Trader Score: (0)
thats a gutsy move! those indicators on the info page are never really that accurate (mpg is always off by 1-2, and cruising range is always just an estimate). But this holds true for all vehicles not just lexus. So the answer is, it depends. But my guess is youve got somewhere between 1-2 gallons left, and your sucking in all that nasty stuff on the bottom of your gas tank, and im also told starving an electronically controlled engine by running it out of gas is not good (probably because it confuses some of the onboard systems) and will result in a check engine light.
__________________
'07 RX 350 AWD, Nav
hesham1 is offline   Reply With Quote
Old 06-24-09, 06:45 PM   #3
tommewin
Trader Score: (0)
Since you mentioned fuel, the manual states that when the low fuel light is on, you have at at most 2.9 gallons remaining in the tank.
tommewin is offline   Reply With Quote
Old 06-25-09, 08:12 AM   #4
exmeaguy
Trader Score: (0)
You are daring. There is always going to be wiggle room with the estimate but I do not recommend going anywhere near zero. Don't forget the computer is constantly adjusting the number as you are accelerating and coasting but it's not a precision number, just an estimate.
exmeaguy is offline   Reply With Quote
Tags
cruising, lexus, range, rx350
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Go
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
Copyright © 2000-2008 Internet Brands, Inc. All Rights Reserved
Privacy Policy | Disclaimer | Terms of Use | JOBS
