Go Back   Club Lexus Forums > Lexus Model Forums > RX Models > RX - Second Generation
Sign in using an external account
Register Forgot Password?
Old 01-09-15, 11:32 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Lexus IS Lighting Guides
Print Wikipost
RX330 tail light bulb replacement
Thread Tools Search this Thread Display Modes
Old 04-06-09, 11:04 PM   #1
dfranklin
Trader Score: (0)
Default RX330 tail light bulb replacement
I just had a terrible time trying to do a what should be a trivial task - replace the 168 tail light bulb on the back of a 2004 RX330. Thought I'd share what worked and what didn't.
You start by removing the small plastic access panel on the inside of the vehicle behind the tail light. Small screwdriver, or even your lexus key, can pop it off.
Grab a flashlight, and inside, you'll see 3 sets of wires plugging into different parts of the light assembly. The upper-most set of wires goes into the black plastic tail light socket itself, partially obscured by a gasket. Reach in (small hands help) grab the plastic where the 2 wires go into it, and twist it slightly. It should come loose, and you will be able to pull it outward, and down out of the hole, where you can access the bulb. The 168 bulb just pulls outward from the socket (it's also got a gasket around the base).
It should NOT be necessary (nor as I discovered is it particularly helpful) to remove the 3 nuts holding the taillight assembly onto the vehicle.
Hope this helps someone avoid the frustration I just had.
This ad is not displayed to registered members.
Register your free account today and become a member on Club Lexus!
dfranklin is offline   Reply With Quote
Old 04-07-09, 05:35 AM   #2
mandyfig
Trader Score: (0)
mandyfig's Avatar
The bulb is for the tail light. The brake light which is LED, will require oulling out the assembly. But good tips. It was a pain to take that off and put back in. The dealer replaced one of my brake lights under warranty. They just replaced the whole light assembly. Did not even bother to replace the circuit of the brake LED.
__________________
SC430 WGC-Ecru/RX330 Bamboo Pearl-Gray/IS350 Black Onyx-Gray
mandyfig is offline   Reply With Quote
Old 08-03-11, 06:17 PM   #3
xis
Trader Score: (0)
two + yrs later and this is the best info out there on changing the rear tail light bulb on a RX330
The inner tail light on the lift-gate that turns on when the headlights are on are bulbs (168)... No screws to remove....just a twist of the fingers removes the socket and the bulb just pulls right out.
xis is offline   Reply With Quote
Old 08-04-11, 05:34 AM   #4
mandyfig
Trader Score: (0)
mandyfig's Avatar
I have removed my tails and know how hard this is. Small hands WILL help.
__________________
Old 08-22-11, 01:03 PM   #5
sail7seas
Trader Score: (0)
I replaced the right rear running light with a LED on lift-gate, and the HID headlamp would go out.
Then I used a low amp replacement bulb, recall 161(1watt). and the HID would go out intermittently.
So I changed to a published 2825 (5watt) and HID headlamp works again.
sail7seas is offline   Reply With Quote
Old 10-18-13, 07:24 PM   #6
MattGau
Trader Score: (0)
This is helpful too:
http://www.fixya.com/cars/t1547331-r...ght_2004_lexus
Some tips I wish I'd read here.
1) The actual screw you can undo (the only screw behind the light) is a red herring. I think the engineers put it there as an inside joke. Ignore it.
2) The panel being referred to is THE ENTIRE BACK PLASTIC PART. If you're looking for an "access panel" you'll miss the forest for the trees.
3) I needed a long flat screw driver to get the pins out. The tip about trying to get the pin out of the door and not the pin out of the panel is good. Everything about the "look" says remove the pin from the panel. Another inside joke I suppose.
4) Twist the socket thing counter-clockwise a quarter turn to get it out. Bulb has these little fins things that scream "pull straight down" but again, you guessed it, another inside joke.
And finally, make sure you have the right bulb. I didn't so off to the store again.
I hate to say it but once you get the inside jokes it's pretty easy. My old car was an Audi and it was, for all intents and purposes, impossible - no inside jokes, just flat out "you need to pay someone" to change a lightbulb.
MattGau is offline   Reply With Quote
Old 06-16-14, 03:25 PM   #7
1koolfella
Trader Score: (1)
I just did this and it was a real PITA.
Whenever I turned on the headlights, the notification on the dash would come on. It was the rear driver side that was out, but sometimes I would tap on it and it would come back on. But it was the bulb that was bad.
I wound up taking out the whole assembly and didn't realize I didn't have to but it's good to know that they're not easy to steal.
1koolfella is offline   Reply With Quote
Similar Threads
Thread Thread Starter Forum Replies Last Post
DIY: IS-F & 2009+ Tail Light Installation brociouz IS - Second Generation 49 03-11-15 06:17 PM
LX 570 Tail Light Replacement streborc LX570 0 01-22-15 07:14 AM
SC300/SC400 Interior Lighting Guide Hazelrah Lighting 39 01-10-15 09:32 PM
Marker Light Replacement, 2001 IS 300 RocketSci IS - First Generation 4 08-23-12 05:28 PM
Turn Signals akkord IS - Second Generation 3 05-18-06 10:09 PM
Tags
330, brake, bulb, change, led, light, removal, remove, replace, replacement, replacing, rx, rx330, rx330 tail light bulb, tail, video
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Join ClubLexus
Copyright © 2000-2015 Internet Brands, Inc. All Rights Reserved
Privacy Policy | Disclaimer | Terms of Use | JOBS
Get all contact info
