Rx 330 06 repair manual
Can someone help me where can i find Rx 330 manual? I have this broken plastic on the left side inner air vent under the left fog light. The mechanic
said it is the oil cooler shield. he called lexus for part replace but they don't carry that plastic. They selling it as a whole unit together with the oil cooler.It is attached to the small some kind of condenser on the left airvent.Not sure what it is.
I do have the manual and have spent minutes looking for this. Post a pic and I will do more checking. Good luck.
Or it could be a shield that you can afford not to have.
It is a black plastic shape on the air vent and it attached to the small cooler.
It's just hanging in there, not sure whats the purpose of that plastic since air goes directly to the cooler.
How did you notice that this was broken? Looks like you can glue it back on. You will have to take the engine cover off and then you can access the trim. Remove and glue it back, re-instal. That's what I will do. Good luck. It will be hard to find a replacement.
I went to Lake Tahoe 2 weeks ago and the road was slippery and i hit
the snow metering pole. It damaged my left front bumper, good thing the fog light wasn't hit. Everything fixed right now except this one thing plastic shield. According to the shop , they can replace but as a whole unit includes that cooler system. You're right it is hard to find , i guess i'l just try one the junkyard they might have one of this by luck . I think the plastic can be modified or just remove it if it causing noise or rattle cause it's just hanging in there.
SoCalRX
RX - 4th Gen (2016-2022)
01-04-18 09:56 PM
triplecore
01-17-08 05:02 PM
