RX330 Vanity Mirror Replacement Bulb
Old 02-25-09, 10:37 PM
tenchidono
tenchidono's Avatar
Default RX330 Vanity Mirror Replacement Bulb
Just wanted to put this out there since I didn't see it on the forum already and I think it would be helpful to share what I learned.
As some of you know, the OEM vanity mirror bulb looks like a fuse and it has HTU-14VO.1A stamped on it. I did some research on the web and found this was called an A6220 bulb which is equivalent to 3022.
I learned two things...
1) You can't replace it with the 3022 Festoon bulb from superbrightleds.com since the one from sbl is too thick at 10mm...
2) You can however, go to your local autoparts store and just replace it with the DE3021 bulb (14 Volts, 3.4 Watts). It is a tiny bit short but fits and works fine
Hope this helps!
beneteau
09-07-10 05:41 PM
clewis
08-10-07 10:45 AM
juan01
Maintenance
11-19-03 08:19 AM
Quick Reply: RX330 Vanity Mirror Replacement Bulb
