Shortcut for Connecting Tow Hitch Wiring
Old 03-13-08, 09:52 PM
Dip Don
Dip Don's Avatar
Talking Shortcut for Connecting Tow Hitch Wiring
I installed my tow hitch today and was ready to dissasemble the trunk to connect the wiring harness when I decided to try and do it from underneath the car. In another post here about tow hitches, someone posted photos of the wire connection in the cargo area after they had removed the tool box and left hand tray. I noticed in the photo that the wire connector was close to the body hole with the rubber plug where the wiring runs through.
I removed the rubber plug while under the car and with a flashlight could see the end of the connector through the hole. The connector was about 6"-7" above the hole. The end of the connector is taped, with black electrical tape to a larger wiring harness. I used a "Slim Jim", for opening car doors, and duct taped a single sided razor blade to it. I was able to insert the "Slim Jim" through the hole and slice the electrical tape. The "Slim Jim" has a notched/hooked end and I used that to reach in, hook behind the connector and pull it toward the hole. ( A wire hangar with a hook bent into one end would also work.) The connector will come within 2" of the opening. I kept pressure/pulling on the connector while I inserted the hitch wire (male end) through the hole and was able to get the connector to slip into the female end. It stayed in place while I took a screwdriver and pushed it in until it locked.
Obviously this shortcut only works if you have the tow package with the wiring harness in the cargo storage area.
This post may sound complicated, but it took me longer to type this than it did to join the connectors from underneath.
Old 03-17-08, 03:27 PM
Pookscar
Pookscar's Avatar
Smile Seems like lots of effort
Sounds like something a retired LASD SGT would do!:
Old 03-19-08, 06:55 PM
nparmelee
nparmelee's Avatar
We're installing the same hitch this weekend so this tip will hopefully be helpful to us, thanks!!!
deputy865
SC- 1st Gen (1992-2000)
04-22-16 10:00 AM
beefmc
08-03-15 08:06 PM
dawhorl21
05-08-14 07:21 PM
CantSeeMe
Performance & Maintenance
03-21-07 11:10 PM
12-05-06 09:59 PM
Quick Reply: Shortcut for Connecting Tow Hitch Wiring
