L.E.D bulb replacement
Old Jun 17, 2008 | 09:25 PM
tod071's Avatar
tod071
You can find the part #s on sylvania.com and also get lights from v-leds.com.
Old Jun 18, 2008 | 08:03 PM
mwcfire's Avatar
mwcfire
Thanks! Got all the numbers I need from Sylvania and there is a great selection on v-leds!
Any suggestions on the reverse lights? Converting them from Incandesant to LED? Is a 12 LED light bright enough? There doesn't seem to be a Luxeon version of the 921 light.
Old Jun 18, 2008 | 08:54 PM
triplecore's Avatar
triplecore
I am not the orginal poster, but if I used these from your sight.
http://www.v-leds.com/Shop/Control/P...id/0/SFV/32481
will the only work as DRL or can they still be used as my highbeams? which one will give more distance.
Old Jun 19, 2008 | 09:58 AM
NeoNz's Avatar
NeoNz
Originally Posted by DreamParty
Finally!! I installed a pair LED for my licence plate and I will post pix tonight!! Thanks for the help!!
p.s whatever you do, get the high power LED, not the old cheap one
what do you mean high power? which LED on the superbrightled website do you suggest? the 6-bulb? 5-bulb? 4-bulb?
here are some of the ones im looking at
WLED-x6 LED Wedge Base Bulbs
6-LED Wedge Base Bulb
These are very bright for their size, about the same size as a stock 194/168 bulb.
Available in all of our standard LED colors and Warm White
Click to see difference in Warm and Cool White LEDs
More InfoBuy Now
WLED-WHP LED Wedge Base Bulbs
High Power - Pure White 194/168 wedge base bulb
This bulb has 1 High Power LED which is about as bright as the 6-LED bulb seen above
At 4500K, the Color Temperature is between Warm White and Cool White
Old Jun 19, 2008 | 09:59 AM
NeoNz's Avatar
NeoNz
Originally Posted by LEXveryG8
It's not that hard. But it will take some work. You have to make sure you have right bulbs before you install them. Otherwise, your gonna have some problems!
The glove box uses type 74 bulbs and the dome lights are DE3175. Also make sure the voltage are the same.
To open the cover is not that hard, all you have to do is pry open the casing with a flat screw driver. And it's self explanatory from there.
Hope that helps,
LEXveryG8
P.S. Be sure to post some picture of installation! Have fun!
where do you find 3175 bulbs? I could't find it on the superbrightled website! can you link me up to the specific bulbs you bought so i dont end up with some cheap ebay junk thank you!
Old Jun 24, 2008 | 10:30 PM
LEXveryG8's Avatar
LEXveryG8
You can find it directly in the v-led website or other led websites. V-led has wide variety. Here's the direct link where you can find the DE3175 led bulbs:
http://www.v-leds.com/Shop/Control/f...m/1/menu_num/2
Hope that helps!
Old Jun 25, 2008 | 12:22 PM
NeoNz's Avatar
NeoNz
2008 LEXUS RX400h (With HID (high intensity discharge) headlamps)
Low beam headlamp
HID-D2S
High beam headlamp
9005
9005SU Silverstar ULTRA for Ultra Night Vision - The Whitest and Brightest Halogen
9005ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
9005XV XtraVision Halogen - The Brighter Light
9005CB Cool Blue Halogen - The Whiter Light
Parking light
168
168LL Long Life Upgrade: Up to twice the life of the standard lamp
Front turn signal
992 (7440A)
Rear turn signal
992 (7440A)
Tail light
LED
Stop light
LED
High mount stop light
Assembly
Fog/Driving light
9006
9006SU Silverstar ULTRA for Ultra Night Vision - The Whitest and Brightest Halogen
9006ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
9006XV XtraVision Halogen - The Brighter Light
9006CB Cool Blue Halogen - The Whiter Light
License plate
168
Back up light
921
921LL Long Life Upgrade: Up to twice the life of the standard lamp
Front sidemarker
168
Rear sidemarker
194
194LL Long Life Upgrade: Up to twice the life of the standard lamp
Glove box
74
Dome light
DE3175
Step/Courtesy light
2825
2825LL Long Life Upgrade: Up to twice the life of the standard lamp
Trunk/Cargo area
DE3022
____________________
Old Jun 25, 2008 | 02:59 PM
LEXveryG8's Avatar
LEXveryG8
Low beam headlamp
HID-D2S
High beam headlamp
9005
Parking light
168
Front turn signal
992 (7440A)
Rear turn signal
992 (7440A)
Tail light
LED
Stop light
LED
Assembly
Fog/Driving light
9006
License plate
168
Back up light
921
Front sidemarker
168
Rear sidemarker
194
Glove box
74
Dome light
DE3175
Step/Courtesy light
2825
Trunk/Cargo area
DE3022
Did you get this info from Sylvania?
Old Jun 26, 2008 | 09:47 AM
NeoNz's Avatar
NeoNz
no i made it all up myself, pretty good for a 23 year old wall st analyst.
of course i did, it took 5 seconds to find it on the sylvania website, wondering why nobody posted it up earlier
Old Jun 30, 2008 | 10:38 PM
LEXveryG8's Avatar
LEXveryG8
hahaha...i admire your humor!
Are you changing any bulbs anytime soon?
Old Jul 1, 2008 | 12:29 PM
NeoNz's Avatar
NeoNz
as soon as they come in,... hopefully today or tomorrow. ill post before and after pics! trying to help this forum out with some DIY's as much as i can. I recently put 6x9 door speakers in my RX.. wow they sound amazing, took almost 5-6 hours to custom fabricate and hook everything up with extra sound padding so the door doesn't rattle and its got more sound deadening material then before!
Old Jul 1, 2008 | 05:08 PM
LEXveryG8's Avatar
LEXveryG8
great! post them up once you have them! I just ordered a couple of things lately and I'm gonna install them once I get them.
Old Jul 2, 2008 | 09:22 AM
NeoNz's Avatar
NeoNz
yea im always tinkering with something, its been the lexus as of late although my supra is coming home today from the shop after extensive modifications. I put a full set of neons inside my lexus to match the blue door sills, they look sick
Old Jul 2, 2008 | 02:35 PM
LEXveryG8's Avatar
LEXveryG8
I bet they look good. Quit teasing us!! I wanna see too!
Old Jul 3, 2008 | 09:28 AM
NeoNz's Avatar
NeoNz
i will post up pics soon as I get some time, might take a while though.
the new 6x9's are awesome, i can leave the bass on level 1 and crank up the volume on my stereo up to 51-54 without distortion, before I was only able to crank it up to 45 before my speakers would distort on bass level 2. Gotta love these 5-way pioneers! they are heavy but do the job updates to come as soon as I receive my LEDS!! HURRY UP UPS!!
