2004 RX330 Advice
Old 02-09-08, 10:16 AM
jfelbab
jfelbab's Avatar
Originally Posted by gto406
Yep, spare is present and accounted for
My next challenge is to figure out how/why the rear wiper doesn't seem to work. I noted a switch on the front console (beside the frt/seat heater controls) but when I push it (even for a period of time) nada. I am wondering if the rear requires washer fluid, and if so, where does it draw from (the front resevoir)?
I am purchasing a set of owners manuals on-line today. Will be for a US car, but hopefully not wildly different than the Canadian spec cars. $32 US seems like a good deal (I would imagine the dealer is at least $50+).
Cheers,
Brian.
The rear wiper is controlled by the very end of the stalk that controls the regular wipers.
Old 02-09-08, 10:56 AM
gto406
gto406's Avatar
I just purchased my '04 owners manual set on eBay ($32 bucks shipped to the Great White North) with a leather case too.
I appreciate you guys helping me out, until I can 'begin to read for myself' .
Many thanks Jim!
Brian.
Old 02-11-08, 09:21 AM
mandyfig
mandyfig's Avatar
Read them at least twice, you will appreciate what you miss on your 1st go around.
Old 02-11-08, 10:28 AM
dcrx350
dcrx350's Avatar
Cheers,
Brian.
That switch on the front console (beside the frt/seat heater controls) is probably for your headlights. When you push it, it sprays your front headlights with warm windshield wiper fluid to help get rid of any ice or snow.
The back windshield does draw fluid from the front resevoir also so you only have to fill the one.
Hope that helps at least until you get ur manual : )
Old 02-11-08, 06:33 PM
gto406
gto406's Avatar
Thanks Delia/mandyfig,
I thought that is what that switch was/is. Does it work anytime or only at rest (with the RX in park)?
I went to the dealer today, and checked on the status of the warranty. Unfortunately my RX's in-service date was April of '03, so the warranty is out. Not sure if I should consider an extended warranty (through Lexus) or not.
Any thoughts on this appreciated.
Cheers,
Brian.
Old 02-12-08, 04:51 AM
mandyfig
mandyfig's Avatar
Unfortunately, if you wanted to get the extended warranty from Lexus, you need to get it before your 48 mo/50K miles were up. But check out other options. If you had all the TSB's done on the car, you should be good to go. Insurance is insurance. It pays for peace of mind. Sometimes, it does not pay at all.
Old 02-12-08, 05:37 AM
dcrx350
dcrx350's Avatar
Mandy makes a good point about the warranty. Now about the headlight de-icer...hmm...not sure whether or not you need to be parked for it to work. To be honest, i've only ever used it while I was stopped.
Old 02-13-08, 03:03 PM
grouch
grouch's Avatar
Push the button at any time and the washer's work when the headlights are on. When the headlights are on and you use the windshield washers, the headlight washers will activate once with the W/W washers.
ls3some
ES - 6th Gen (2013-2018)
12-19-18 06:42 AM
Cocal
RX - 4th Gen (2016-2022)
04-02-17 02:32 PM
JoeInHNL
11-29-09 04:17 AM
dhamaka127
04-02-08 01:10 PM
fittrainer
06-04-07 02:43 PM
Quick Reply: 2004 RX330 Advice
