Go Back   Club Lexus Forums > Lexus Model Forums > RX Models > RX - Second Generation
Sign in using an external account
Register Forgot Password?
Rx330 Brake Pads replacement
Thread Tools Search this Thread Display Modes
Old 05-02-10, 02:33 PM   #106
RX330inFL
Trader Score: (0)
With 75K on the car, am guessing I am coming up in the near future on at least replacing the front pads again. They were originally replaced at 40K. Did not turn the rotors as it was not needed. At this point I still have no vibration under braking and the rotors still look good. Leaves me with two questions:
1. Should I worry about the need to replace the rotors since they were not turned previous and more than likely would not be turned this time around either?
2. Does anyone know a source for pre-painted calipers? I saw a previous post where someone had done theirs. Only reason why I am even considering is that the ones on my car are showing rust you can see through the wheels. Would like to clean that up if possible. Figure if I am going to have to take them off the car to be powder coated I might see if someone already has the finished product.
Any input, as always, is appreciated.
This ad is not displayed to registered members.
Register your free account today and become a member on Club Lexus!
RX330inFL is offline   Reply With Quote
Old 07-12-10, 06:41 AM   #107
mandyfig
Trader Score: (0)
mandyfig's Avatar
To the top, somebody's asking about size of bolts. 14 mm on sliders. Maybe 17 mm on rotor bolts (Lexus turned my rotors).
__________________
SC430 WGC-Ecru/RX330 Bamboo Pearl-Gray/IS350 Black Onyx-Gray
mandyfig is offline   Reply With Quote
Old 07-12-10, 07:56 AM   #108
MrBooby
Trader Score: (1)
MrBooby's Avatar
Quote:
Originally Posted by mandyfig View Post
To the top, somebosy's asking about size of bolts. 14 mm on sliders. Maybe 17 mm on rotor bolts (Lexus turned my rotors).
No I wasn't asking about these bolts. I meant the ones that you use to remove the rotors off the hub. But thanks anyway.
MrBooby is offline   Reply With Quote
Old 07-12-10, 08:58 AM   #109
mandyfig
Trader Score: (0)
mandyfig's Avatar
Ok, gotcha.
__________________
Old 01-06-11, 06:18 AM   #110
radman2008
Trader Score: (0)
radman2008's Avatar
Default 2005 RX Brake job
Mandyfig:
At 60K on my wife's RX. When my wife took it in for a recall item, the dealer said front brakes are at 3 should be done. They wanted $300+ for each axle - with no rotor issues.
I followed this discussion to the 5th page but wanted to confirm a couple of points:
  • Pistons: on 2005 both are push type, not rotating, so I don't need the rotating tool?
  • Brake Fluid: some posts suggested changing the fluid completely out after 2 years. Sounds like good advice but what is the correct way to do that?
  • Components: The pdfs of the components were from the 2004 RX330 manual. I am assuming these are the same for the 2005?
  • Components: the pdfs have indicators that show parts to be replaced & different grease types. Non resualbe parts included items like piston seal, cylinder boot, dust boots, etc. Before buying these, do any of these require special tools to replace?
  • Pads & Rotors: If Lexus will do it, I plan on having them turn the rotors. And I plan on using OEM pads from the dealer, which I haven't priced. One post mentioned a source in this forum for parts?
I am a fair 'tim the tool man' and have done brakes in the past on my non-import cars. I plan on doing both axles when I do this. It has been several years and this being my wife's car I want to do the job to the nth degree (so no: "...I told you we should have let the dealer do this...."!)
Your posts and photos were VERY, Very instructional. Thank you in advance for your help and clarification!
radman2008 is offline   Reply With Quote
Old 01-06-11, 11:07 AM   #111
mandyfig
Trader Score: (0)
mandyfig's Avatar
Thanks for the compliment.
For your 2005 brakes:
1. They are identical to 2004. Hence what you see, is what you can do.
2. It is really fairly simple and there are no special tools required other than what has been shown.
3. As long as your sliders are moving freely, then you do not need to take apart and re-lube. If you decide to do it, there are lubricants available in your local auto stores. They should be good enough to use on our RX.
4. Pads, I used OEM pads, you can purchase from our supporting vendors, Sewell and Carson and you will get a discount.
5. I suggest you take off the rotors and take it to a reputable shop to get it turned. Again this should not be hard to do. If you do not have vibration when applying the brakes and the rotors look good, no grooves and the there are no serious lips, you should be ok. But this is 60K, get it turned. If the thickness falls below spec (based on your mileage, I doubt it) then you have to get replacement rotors. Again Sewell or Carson should be able to set you up.
6. Rears will be much easier to do, just keep note, they are not designed the same, just follow the DIY. Your rear rotors should last you the life of the car, they are hardly worn.
All in all you should do fine. PM me anytime.
Good luck.
__________________
Old 01-06-11, 11:10 AM   #112
mandyfig
Trader Score: (0)
mandyfig's Avatar
Brake fluids. You can do a 2 person bleeding and can flush out the old fluid this way. That's fairly easy. You will need an assistant. 3 would be lovely. The 3rd replenishes the fluid while you bleed and the other person pumps.
There are gadgets out there that allow a 1 person bleeding exercise. Google it.
__________________
Old 01-07-11, 11:08 AM   #113
billy44bo
Trader Score: (0)
I took my 330 to a Toyota store had front and back done for $400 and the Brake Fluid was 85
__________________
2011 RX 450h AWD
Matador Red Mica, Parchment
LED Headlamps,Mark Levinson,Heads-up Display, Rear-Seat Entertainment System & Navigation System Package ,Luxury Package, Intuitive Parking Assist ,Paint Protection Film,Remote Engine Start,Comfort Package ,Tow Prep Pkg, Side Body Molding,Mudguards,Door edge guards
billy44bo is offline   Reply With Quote
Old 01-07-11, 11:10 AM   #114
mandyfig
Trader Score: (0)
mandyfig's Avatar
$485 is reasonable.
__________________
Old 01-07-11, 11:18 AM   #115
billy44bo
Trader Score: (0)
it was a lot better than what lexus store wanted
__________________
2011 RX 450h AWD
Old 01-07-11, 11:28 AM   #116
mandyfig
Trader Score: (0)
mandyfig's Avatar
Well by the time you get done with your Starbucks coffee and cookies....it will even out, LOL!
__________________
Old 01-08-11, 08:08 AM   #117
billy44bo
Trader Score: (0)
I do not drink coffee so I had them drive me home and worked in the yard while they did the work. Toyota store only 3 miles away so no need to pay for the car you get at Lexus and trust me you are paying for that "FREE Car " when you go there.
__________________
2011 RX 450h AWD
Old 01-09-11, 08:36 AM   #118
mandyfig
Trader Score: (0)
mandyfig's Avatar
Other than clean warranty work at a Lex dealer, I do all my stuff on the car. I know all of what you get is added to the bottom line. But since you purchased the Lex, take what's included, JM2C.
__________________
Old 01-09-11, 02:55 PM   #119
billy44bo
Trader Score: (0)
Will never take the car back to the Dealer that I got the car from. Do not see eye to eye with the service manager and almost got in a fight with him over how crappy of a job they did clean the car. If I ever have to have warranty work done will dive or have it towed to New Orleans 150 miles west of here. Other than that the Toyota store or the Mercedes-Benz dealer will be doing the work on my 450h. Never ever will the joke of a Lexus dealer service department get their hands on my 450h.
__________________
2011 RX 450h AWD
Old 04-12-11, 09:46 AM   #120
mandyfig
Trader Score: (0)
mandyfig's Avatar
Bump, several folks looking for this DIY.
__________________
Similar Threads
Thread Thread Starter Forum Replies Last Post
Issue with brake purchase from Sewell Jimmybasco Site Suggestions & Problems 6 01-07-15 09:03 PM
Sewell brake pads, low dust? Phresh2010 Suspension and Brakes 23 06-01-14 04:33 PM
new brake pads? Fuzzie SC 430 5 02-06-14 11:17 PM
TX FS: Brand new OEM front/rear Brake Pads IS250 heyarms 2Gen IS250 / IS350 / IS-F Classifieds (06-13) 2 09-04-13 05:18 AM
Brake pads from Sewell iolmaster RX - First Generation 3 09-16-11 11:15 AM
Tags
330, 3mm, audio, brake, brakes, break, gx470, lexus, long, pads, rear, replace, replacement, rx, rx330
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Join ClubLexus
Copyright © 2000-2015 Internet Brands, Inc. All Rights Reserved
Privacy Policy | Disclaimer | Terms of Use | JOBS
Get all contact info
