VSC Light and Check Engine Light
#121
My CEL, VSC and slip indicator lights came on in my 2008 RX350 while on a trip last night. Upon going to AutoZone this morning, the engine error codes are C1201 and P0015 x 3 (it was on the reader three times). Any ideas what this means? The gentleman that helped me said the cam shaft sensors and solenoids may be going out. Any ideas? Thanks.
#122
https://www.clublexus.com/forums/rx-...ode-p0015.html
https://www.clublexus.com/forums/es3...201-b2799.html
Have you been keeping up with the regular maintenance?
#123
Yes, its had regular service at the proper intervals. And of course, the warning lights went off as I drove around this afternoon. I will look at taking it to the dealership the next time this occurs.
Thanks for those links.
#125
Good info .... Thanks all.
2nd Gen 2005 RX300 -1mz (Trinidad WI)
Recently the CEL and VSC lights came on...did the scan and got a P0037 code.
Ordered the b1s2 oxygen sensor off toyotapartscheap.com oem part # 89465-48180.
I'm not sure how to cross reference it yet to the Denso part #.
I've seen reference made to upstream / downstream right and left and to the pre-cat and post-cat sensors but I'm unsure which is which?
#126
I had my gs430 for about a month and before I knew it. Check engine light. Then vsc / vsc off light a few days later. After searching this forums I decided to try looking at my gas cap. Sure enough the gasket had a crack and it was brittle. Thinking I had solved the problem I went to Lexus parts and bought a $32 gas cap. Well after 200 miles it just got worse. Now it started missing(sputtering). Over it I took it to my machanic. Code reader, miss fire 5 , misfire 7, fuel defusuer?
Turns out the problem was, bad ignition coil on cylinder 5, bad ignition coil cylinder 7. $147.00 in parts, $6 12 pack of sunkis soda, and 3 cheeseburgers and $32 in labor. No check engine light no vsc light. Car runs even stronger
#128
Check Engine, VCS, and Traction Control light were all lit on dash
Today after a short 10 mile drive, the Check Engine, VCS, and Traction Control light were all lit on dash. I got the code P0355 Ignition coil E primary/secondary circuit. This says the 5th coil or plug triggered this (its the rear cylinder closest to the driver). The car runs great. Could not detect a problem with the way the car ran. I stop and started the engine a few times and the last time I restarted the engine, the lights where all off like normal. I then went for a 40 mile drive, and the lights stayed off. 141,500 miles on the car. I am the second owner and I purchased it with 140,000 miles on it from a dealer so I do not know if the coils or plugs have been replace. I pulled the front three plugs out and they all looked fine .Any thoughts on this? Thanks!
ry2216
ES - 5th Gen (2007-2012)
10-05-20 10:02 AM
Jet Wrench
RX - 1st Gen (1999-2003)
04-12-07 08:06 AM
