RX350 - CD Changer Error Message 3
Super Moderator
When it comes to a TSIB, there has to be a known fix. The problem I see is Toyota/Lexus does not make the audio system whether it be Mark Levinson or the standard audio system. They can't issue a TSIB fix if the manufacturer of those equipment doesn't have a fix or doesn't recognize there is a problem. The most they could do is change manufactures, but that would come perhaps in the next generation.
I had the error 3 problem on my 07 RX350. It happened a couple of times and seemed to clear itself after a day or so, then it happened a third time and it would not reset. The dealer had to replace the unit under warranty. Had to send my old one back to japan to get my CDs back.
Dave S.
Dave S.
Could you post the information on where you sent it in for repair? Am sure others in the same situation may be interested in that info. Luckily, mine works fine.
5705 Enterprise Parkway
East Syracuse, NY 13057
Turn around time for repair is 3 days
It will happen to all of them have to send my Mark Levinson out it was $450 for the repair. Look at the CD’s you are using if you can see though they then do not use them unless yours is set to use CDR and others. The one in my 05 was not also the Cd’s your burn are thicker than a store bought one and that will make the unit stick and give you the error 3 error 4 is a read error . You get this a lot if you put in the ones that you can hold up to the light and see though it. The leaser is looking for the light to reflect back but one the semi clear ones. The light will not reflect back the way the unit is look for it. The leaser powers up more and more until it hits it max power setting and then come the error 3 and 4s.They worst part of it if you send your unit out on an 05 with Navigation and I sure the others will be like this is nothing will work in the car. No AC controls, Navigation is out, and the Backup camera is out. AC will keep running on the last setting it was one before the unit removal. My dealer here wanted over $700 to replace the unit but another one 150 miles away only wanted $500 to do the same thing. If I had only called around before I had, my unit put in the mail twice.
I have 07 RX350, the car only has 23,000 miles, however, it's 51 months old, therefore, Lexus Dealers quoted me $600 plus 2 hrs labor to have it swapped out with another unit. I only listen to CD on a long trip where I can't get FM stations and I don't think I've used CD Player for more than 5 times in the last 4 years. I am sure it has been broken for a while, but since I don't use it often, I don't know about the issue until now.
I am contacting Lexus Customer Satisfaction to tell that Lexus should either recall or put out a TSB for this issue, it's so common, there are thousands of Lexus / Toyota owners have seen this problem. Will see what they have to say.
My wife's 2004 had the disc error issue twice. The first time was right after we bought it, and the used car dealer fixed it for free. The second time, we waited a few days and was able to get our CD's back out of the unit;-)
I ended up installing a Vais iPod adapter, so we don't use the CD player anymore...
