PCV valve
Old 08-24-10, 02:13 PM
  #46
KevinLanta
KevinLanta's Avatar
Default Location of PCV valve
The Sienna picture above is a good one - use it to find. The valve is to the rear of the engine on the passenger side almost under the manifold. If you look straight down along the left edge of the manifold you will see the valve - a black hose with insulation is coming out of it.
Old 08-24-10, 02:14 PM
  #47
KevinLanta
KevinLanta's Avatar
Default Location of valve
Old 03-08-13, 06:00 PM
  #48
pablo87
pablo87's Avatar
After lurking here for months, finally decided to register and post after several DIY's assisted by this site.
Just changed the pcv valve at 127,000 miles. Had my 2005 Rx330 serviced at the dealer for the first 60,000 miles, they never changed it (and perhaps it was fine). I would not have known to change it except for this thread!
compared to the replacement (Lexus genuine), the original appeared to be barely functional.
Old 03-08-13, 06:30 PM
  #49
RX330inFL
RX330inFL's Avatar
Thanks for the post, pablo87, and welcome to Club Lexus after lurking all this time.
As there is no definitive change interval for a PCV valve on the RX it makes sense that the dealer never changed it out. Unless a CEL comes on or other problem is noted it would more than likely never even be inspected. Back in the day it was a routine item to replace.
I have a replacement PCV valve, NAPA and made of metal not plastic, ready to go when I see the need to replace. Perhaps sooner rather than later.
http://www.napaonline.com/Catalog/Ca...525_0182360673
Old 03-11-13, 08:08 PM
  #50
pablo87
pablo87's Avatar
thanks rx330inFl, $6 less than I paid - obviously haven't been lurking enough!!
One thing I didn't do is clean the hose with compressed air, it only dawned on me later. Easy enough to do.
Last edited by pablo87; 03-11-13 at 08:15 PM. Reason: much cheaper at napa than lexus
Old 04-08-13, 08:27 PM
  #51
1koolfella
1koolfella's Avatar
The pcv valve is not plastic in my 350.
I was able to remove it and clean it like JGR7 mentioned. Screwed it back in and the vehicle seems peppier.
I'm at 46,000 miles and I'm pretty sure it's never been removed because it was a pita to remove.
I'm going to keep an eye on my fuel usage to see if it made a difference at the pump.
Old 11-28-20, 06:43 AM
  #52
Orlard3
Orlard3's Avatar
Originally Posted by r1lee
I just figured it out, instead of using the PCV valve to feed it through. I will use the Vacuum Switching Valve PWM. This will take the seafoam directly to the Intake Manifold.
R1lee, can you show where the vacuum switching valve PWM is?
Old 12-16-21, 11:46 AM
  #53
iMSQ
iMSQ's Avatar
Hi all,
What does the PCV valve do? What are the signs of bad PCV? Thanks.
Old 12-16-21, 05:45 PM
  #54
Felix
Felix's Avatar
Originally Posted by iMSQ
Hi all,
It allows what gets by the rings to get reburned thru the intake when the valve is open under cruise, light throttle as the valve is operated by vacuum. Idle & heavy throttle the valve is closed as the vacuum drops vs under light throttle w/ high vacuum. IIRC pcv's are required on '67 & newer vehicles. Vehicles had open oil caps & road down draft pipes vs pcv closed systems. When the valve is plugged up w/ oil debris. Yea you can clean it w/ brake clean, carb clean. A shake of the valve & you'll hear the valve rattle like a spray paint can. Really best to just replace it, its not that much vs the time & the cost of a can of brake clean/carb cleaner.
lukeisf11
IS F (2008-2014)
23
12-18-23 01:23 PM
Brn2drive
GX - 2nd Gen (2010-2023)
56
04-18-23 02:20 PM
McCloudsZJ
Performance & Maintenance
18
05-15-19 11:28 AM
Nova
SC400 / 300 Classifieds
04-28-12 02:55 PM
brazil
11-26-08 01:12 PM
Quick Reply: PCV valve
