Will 18x8 45mm offset wheel fit without rubbing?
I'm looking at getting either the 5-spoke GS430 wheels or the split spoke IS250/350 wheels to replace the stock setup. Since they come in 18x8 and 45mm offset (at least for the GS430 wheels) would they fit without rubbing? I would also be using th stock 235/55/18 sizing as well. And don't want to have the wheels protrude out of the wheel well either.
Thanks guys
Thanks guys
Super Moderator
I'm going to have to say probably not. You may not have enough back spacing. and it may hit either the rear strut, or the inner rear fender liner.
The stock rims (If 17" are 6.5" wide with a +35mm offet). I personally ran a 20X8.5" with a +20 offset. This combo had a reduced backspacing of 10mm from stock. I cleared the strut, but marginally and I also had about a 1/4" space between the tire and rear inner fender liner.
With a 8" +45 offset rim, you will have 29mm less back spacing clearance. This may put you over the edge. Now, keep in mind this is just a static calculation. Each manufacturer may have slightly different specs for the same 8" +45 wide rim and also the size of the tire is a major factor as well. I ran oversized 255/50 tires. A traditional 245/45 tire may have enough clearance.
As for the rims sticking out past the fender you have more than enough room. The back spacing is the issue in this case.
Super Moderator
Yes and no. The stock 18X7" rims are also +35mm. The rims you want are 8" +45. Since the rims are wider, they will move out by 3mm and with the +45 offset reduce back spacing by 23mm. If you measure the distance between your rim/tire and struts and inner fender liner see if you have more than 23mm to spare. If you do, the rims probably will fit.
I checked and it seems that there's about 1 1/2" - 2" (38mm+) of space between the tire and the strut in the front, and barely 1" (25mm+) of space in the rear. Cutting it really close.
Well, I saw that the gap between those two points weren't more than an inch apart and that's what I was goin by. The close tolerance mean that having the tires will rub against the spring perch if you go over bumps. But having spacers would probably lessen the chance?
Super Moderator
