Atf
Old 11-16-06, 05:50 PM
shikbas
shikbas's Avatar
Default Atf
Hi gys,the atf for rx330 is T IV,can the synthetic mobil one be used as atf.thanks,when it should be changed .
Old 11-16-06, 06:12 PM
cowdung
cowdung's Avatar
yes, its mobil 3309. I would still stick with Type IV. Its one of the best atf around.
Old 11-16-06, 07:04 PM
Tammy
Tammy's Avatar
It is not suggested you change from the type IV Toyota ATF fluid.
Are you all wheel drive or two wheel drive ?
If you are AWD, every fifteen thousand is recommended for a multiple drain and fill.
ajgregory
01-13-20 11:44 AM
jcjr
RX - 1st Gen (1999-2003)
13
06-29-13 05:34 PM
infinirx
01-03-12 06:09 AM
MASSMINI
15
07-30-11 12:08 AM
autodriver
05-16-04 11:53 AM
Quick Reply: Atf
