Wierd MODE button behavior with SLS/SLI in RX350...
Old 10-22-06, 11:18 AM
spikerjack
spikerjack's Avatar
Default Wierd MODE button behavior with SLS/SLI in RX350...
Well here is something ***very wierd*** I discovered in my Vaistech SLS/SLI configuration on my RX350 when trying to use the MODE button on the steering wheel to switch between all audio choices. Here is what happens...
Starting on SAT1....I press the MODE button -> goes to SAT2
From SAT2...press MODE button -> goes to SAT3
From SAT3...press MODE button -> goes to FM1
From FM1...press MODE button...here is where it goes wacky. It goes to FM2 for about a half a second....and then resets back to SAT1! Using my mode button on the steering wheel....there is no way for me to get to either TAPE or DISC functionality (including CD2 where I have the iPod emulation with the SLI) using the MODE button. Direct access via the buttons on the radio assembly works fine.
Anybody else able to confirm this behavior? More specifically...since I have both the SLS and SLI...I am curious if this happens if ONLY the SLS or SLI is installed.
Any confirmations, thoughts or ideas is appreciated....
Thanks,
--Scott
Old 06-14-11, 09:17 PM
andy10306
andy10306's Avatar
I am having a similar problem when I hit a bump on the right side. The steering wheel feedback from the bump seems to be making the mode button react in a bizarre manner. I have not contacted the dealer yet. I dont have SAT but I do have an ipod. Good luck! Andy
Old 06-15-11, 01:08 PM
rx400h1976
rx400h1976's Avatar
Thanks,
--Scott
Has it ever worked correctly on your RX?
What year is your RX?
pbxcomm
04-17-23 07:33 AM
clammbo
11-07-21 04:46 AM
AL13NV8D3R
06-06-14 06:18 PM
blksolara
10-21-13 11:56 AM
Quick Reply: Wierd MODE button behavior with SLS/SLI in RX350...
