Question on the HID autoleveling
Old 10-07-06, 07:42 AM
meowkub
meowkub's Avatar
Default Question on the HID autoleveling
I got my RX350 on MAy06. At first i noticed that everytime when i turn on the headlights, i would see the light move around like they're doing adjustment or something. But now I don't see them moving when i turn on the headlights anymore. Anyone know is this normal? Are the headlight supposed to do the adjusting everytime I turn on the headlight? your answer is much appreciate.
Old 10-07-06, 08:34 AM
jim256
jim256's Avatar
They do go through an adjustment cycle when you turn on the headlights, and they steer through turns when exceeding 18 mph and stop when speed reaches 3 mph. There is a disable switch but if that is activated you would see an AFS OFF warning light on the dash. If they have failed, there should be a warning message. It's all explained in the manual.
Old 10-07-06, 10:51 AM
RX_brain
RX_brain's Avatar
My RX330 never adjust if I manually turn on the lights. It does it only when I start the car and the HL switch is set to "AUTO" when it's dark enough for it to turn on.
Old 10-07-06, 12:11 PM
jim256
jim256's Avatar
RX_brain--'May be the same on mine--never turned them on manually where I can observe it, but on Auto when starting the car in the garage, they always go through a cycle. Thanks for the info.
Old 10-07-06, 05:39 PM
meowkub
meowkub's Avatar
thank you all for the answers, i tried leave the HL to auto and turn on the car, but the HL still didn't go to the adjusting cycle. I remember my HL went through the cycle when I turned it on manually, but now the manual way wouldn't work either. If I reset the ECU would it fix the problem?
Old 10-07-06, 05:58 PM
rxdriver
rxdriver's Avatar
I've only noticed this adjustment happening when the lights are "on" (or "Auto" in a dark place, like a garage) when the car is first turned on. It's also more dramatic if the car is not on a level surface, like a driveway that slopes down toward the street.
Otherwise, I don't notice anything.
Old 10-07-06, 11:40 PM
RX_brain
RX_brain's Avatar
Since your RX is still under warranty, I'd say have the dealer check it out first. It's definitely not functioning properly.
Old 10-09-06, 05:15 AM
markpaco
markpaco's Avatar
IIRC, the lights should still swivel with the lights off; you just don't see it because you are in the car. Either your AFS is off or malfunctioning.
kl323
10-24-19 06:53 PM
LS430_Mike
05-09-09 02:42 PM
Cali_Girl
07-31-06 07:24 AM
mikevanle
03-28-05 09:12 PM
HollyA
03-25-05 05:23 AM
Quick Reply: Question on the HID autoleveling
