View Poll Results: What gas do you put into your 2RX?
Premium
0%
Medium
0%
Regular Unleaded
0%
Voters: 0. You may not vote on this poll
Do you need Premium Gas in the 2RX (merged discussion threads)
Old 01-10-12, 04:52 PM
  #526
petenick
petenick's Avatar
I'm surprised nobody mentioned that his trip home may have involved more uphill driving - indicating that the trip back down to the dealer would have had a greater amount of downhill driving, causing the fuel efficiency difference.
Personally, after 8 months of driving, I average 23-24 MPG in my 04 RX 330 in mixed driving using 93 octane, and 19-20 MPG using 87 or 89 octane. Same gas station next to my house is used for all fueling. Ethanol of up to 10% is in any octane of fuel from this particular station. I calculate fuel economy manually with gas station receipts and the trip odometer...but it's usually within 5% of the vehicle's computer readout. The best economy I've gotten was 27.3 MPG from a 200 mile round trip, mainly highway driving at 75 MPH, with 93 octane fuel. Similar weather conditions and 87 octane fuel gave me 22.8 MPG on the same route.
My occupation partially involves seeing many different fleet and personal vehicle historical records which includes their fuel economy records. I typically notice a 7-10% MPG increase for any vehicle's fuel records when they've used premium fuel.
Old 01-11-12, 07:52 AM
  #527
lexus114
lexus114's Avatar
If your getting that kind of millage out of an awd....thats simply incredible!
Old 01-11-12, 08:39 AM
  #528
jfelbab
jfelbab's Avatar
My 2004 RX330 AWD.
Minimum MPG 17.2
Maxumim MPG 28.7
Average MPG 22.9 over life of vehicle
If you study the attached graphic you can see a couple interesting things. These MPG numbers are measured and not computer indicated.
1. My city/rural driving MPG improved markedly after the transmission reflash and I put new tires on the vehicle. There was no apparent change to my freeway MPG.
2. I take many long (1,500 mile) cross country trips where I set the cruse at 70-75 and run until I need to gas up again. I take the same freeway routes for these trips so I get a reasonably good testbed for evaluating MPG. I have have gotten the highest mileage when I run premium in my RX. I get good but less mileage with regular gas in the tank but this is only apparent on freeway trips. In the city/rural driving I don't SEE any change but I do FEEL the added power.
Old 01-11-12, 09:58 AM
  #529
mandyfig
mandyfig's Avatar
Well, data is data. Must say very convincing.
Old 01-11-12, 10:20 AM
  #530
lexus114
lexus114's Avatar
my millage rite now is around 17-17.5. And when it gets real cold out i.e 25degrees. It drops down to 16.5. On Premium fuel none the less. Summer, I get anywhere from 19-20 all around millage. Same driving.
Old 01-11-12, 07:28 PM
  #531
petenick
petenick's Avatar
Yes, it's AWD. Has 89,000 on it now. 18" Bridgestone Alenza tires.
Old 01-11-12, 08:45 PM
  #532
RX330inFL
RX330inFL's Avatar
Actually, I thought about that and looked into it. Am familiar with approximately where lexus114 is located and exactly where the dealership is. So, I put the information into Google Earth. The difference in altitude was only a few feet along the route. Nothing that could make a difference.
Having grown up in PA and gone to college there I am familiar with many sections of the state. For example, when I would go to Penn State on the way back it would pretty much be all downhill for miles and miles. Used to try to see how long I could coast before needing to use the gas.
Old 01-11-12, 09:55 PM
  #533
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
Originally Posted by pauljcl
+1 - agree
Originally Posted by nopcbs
Unless your regular is an (evil) ethanol blend and your premiun is not an ethanol blend (and your tank was empty when you put the premium in), what you describe CANNOT be a consequence of using premium. The BTU content of the two fuels is identical. Premium will have higher octane and if you have a high comprerssion engine that you are flogging, it will perform better than it would with regular with the ignition timing "bumping off" the knock sensor. Premium may also have a better detergent package, but you would have to have a pretty dirty engine (from bad regular use) for that to make a difference and it would not happen as quickly as you describe.
What you describe cannot happen. Sorry.
- nopcbs
Actually, it can and it does happen... I will try to explain...
As a general rule, you can make more power by advancing ignition timing. Advance ignition timing too far and you will get knock. Use of a higher octane fuel will allow more ignition timing, thus more power per combustion event... More power per engine cycle with no more fuel used means that you can relax your foot a couple percent on the throttle, meaning less fuel used to make the same power...
Essentially, the biggest deciding factor as to what octane fuel an engine requires is how much ignition advance (in combination with compression ratio) the engine is tuned for. Detune it a little and you can run less octane fuel... All new car engines do this automatically by listening for knock. They sense knock (due to anything, including low octane fuel), and they retard engine timing...
Great example - tuning a EVO - 28 psi boost, huge injectors, etc... base tune, not a lot of timing... made decent horsepower, 470ish range. added 3-7 degrees of timing (depending on where in the map), and the car made just over 500 hp... Since more power is available, you can run less throttle, which means less fuel consumption to make the same power... Even at a cruise speed, you can make the same power with less fuel...
Old 01-12-12, 06:42 AM
  #534
lexus114
lexus114's Avatar
Pretty impressive their dude!
Old 01-12-12, 07:15 AM
  #535
lexus114
lexus114's Avatar
And less combustion/exhaust temps too. Helps the cat converters, and air fuel ratio sensors live a longer happier life.
Old 10-05-12, 05:55 PM
  #536
bnewcol
bnewcol's Avatar
Default Gas grade for 2009 RX
Hello
The manual says to use gasoline grade of 91. With prices skyrocketing out here in California, would it be OK to go to 89 or 84? Was wondering what it would do to the engine.
Also, do you know if this model uses a special synthetic oil, or just standard oil?
Thank you.
Old 10-05-12, 06:30 PM
  #537
RX330inFL
RX330inFL's Avatar
Originally Posted by bnewcol
Hello
Thank you.
Believe you mean 87 octane and not 84. Still, would stick with 91. The 2nd Generation RX350 engine is particular to its fuel requirements. Putting in a lower octane fuel will cut performance and fuel economy to the point where it is not worth doing.
As for oil, plain old dino oil will suffice for your 5K oil change interval. From the Owner's Manual:
Do you need Premium Gas in the 2RX (merged discussion threads)-screen-shot-2012-10-05-at-9.22.26-pm.png
Old 10-05-12, 06:47 PM
  #538
bnewcol
bnewcol's Avatar
Thank you so much!!!
Attachment 259997
Old 10-06-12, 07:25 AM
  #539
GatorMike
GatorMike's Avatar
It's a Toyota engine. Designed for the lowest common denominator Camry driver. It'll go 50k without an oil change. (total joke....don't try this)
You can use any grade fuel, but using lower octane will cause the ECU to advance or retard ignition accordingly to protect the engine from pre-detonation and knock. You'll lose 5-10 hp using a lower grade which, as someone else said, can adversely affect fuel mileage. Around here it's a $0.30 difference between 87 and 93 octane. With a 19 gallon tank, if you ran it bone dry you'd be saving a whopping $6 a tank. If you figure an average 15k a year that's 750 gallons a year at 20mpg combined. That's $225 a year. If that's going to break you, you probably shouldn't be driving an RX.
Old 10-06-12, 10:42 AM
  #540
bnewcol
bnewcol's Avatar
I love this answer! thank you for doing the math for me...the RX was a gift, yes, a gift. A wonderful gift. I used to have a 4Runner and bought the lowest octane gas. Right now in SoCal, we are running out of gas (some pumps are closing) and prices are hitting $5.00....I doubt they'll run out of 91, so I will stick with it. Just wondering if in emergency, once would be OK.
Quick Reply: Do you need Premium Gas in the 2RX (merged discussion threads)
