Go Back   Club Lexus Forums > Lexus Model Forums > RX Models > RX - Second Generation
Thread Tools Display Modes
Prev Previous Post   Next Post Next
Old 08-08-05, 10:47 AM   #1
thwang99
Trader Score: (0)
Send a message via AIM to thwang99
Default Removing roof rack from RX400 / 330
Hi all,
So, removed the roof rack this weekend, still need to get a replacement rubber strip, anyone know where to get this? Anyways, it was very easy! I've posted some pictures below:
First lift up on the plastic covers, and pull forward/backward to remove them. They should snap right off.
Then remove the screws.
Now lift the roofrack off the car, be careful not to scratch the paint! Here's the removed roofrack, saved 14 pounds in weight from the top of the car, and reduces drag:
One thing that you can do is to remove the sliding rails first, just slide them towards the rear of the car once you've removed the plastic covers. You'll have to loosen two retaining screws to get them off. This way you can remove each roof rail one at a time instead of having to take the whole roof rack assembly off at once.
thwang99 is offline   Reply With Quote
Tags
rack, rail, remove, roof, rx350
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Go
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
Copyright © 2000-2008 Internet Brands, Inc. All Rights Reserved
Privacy Policy | Disclaimer | Terms of Use | JOBS
