330 Interior Sulfur Smell
I've noticed that when I push the engine semi-hard (from a rolling stop revving to about 5K) then cruising @ 70mph, this obnoxious sulfur smell comes in thru I guess the AC. Is this normal? Never happened on my IS or Prelude.
dubsonlexus
Re: 330 Interior Sulfur Smell
Does it smell like gun powder? My last car had the same issue. My mechanic checked and found a small leak on the rubber tube that leads to the PCV valve.
No such problem on my RX300.
The AC button needs to be on recirculate or else the AC draws air from outside of car.
When running the AC on the coldest setting the AC should shift to recirculate automaticly.
But any other temp set will cause it to bring in outside air and outside odors.
My IS does the same thing. I've never been able to do it when I've taken it to the dealer though. Usually any semi-aggressive driving of the engine elicits a definite sulfur (rotten egg) smell.
dubsonlexus
