Oil drain plug bolt size
Old 04-01-03, 03:57 PM
EnzoRX
EnzoRX's Avatar
Default Oil drain plug bolt size
Hi all,
Does anyone know the size of the oil pan drain plug bolt size for a 2001 RX300? Is it a 14mm 6 point socket? I need to go out and buy the correct bolt size for my ratchet. Thanks.
Old 04-02-03, 06:40 PM
BurnishedGoldRX
BurnishedGoldRX's Avatar
Default Re: Oil drain plug bolt size
Originally posted by EnzoRX
Hi all,
I always use a 15mm on my '99. I don't see why they would have changed the size of the bolt from '99 to '01.
Old 04-02-03, 09:09 PM
EnzoRX
EnzoRX's Avatar
Thanks BGRX...I will go out and buy a 15mm socket. Do you happen to know the proper torque setting for the oil pan drain plug?
Old 04-02-03, 09:33 PM
BurnishedGoldRX
Quoting from Alldata:
Clean and install the oil drain plug with a new gasket.
Torque: 45 Nm (460 kgf-cm, 33 ft. lbs.)
Old 04-03-03, 08:47 AM
EnzoRX
EnzoRX's Avatar
Thank-you BGRX! Time to go look into buying a torque wrench too.
propcop
03-29-16 09:38 PM
User1321989
Performance & Maintenance
12-05-15 10:55 AM
natman
12-13-13 06:27 AM
xspsi6
08-22-12 04:51 PM
dtLS400
04-11-12 06:55 PM
Quick Reply: Oil drain plug bolt size
