P1150 & P1155 - changed A/F sensor - now P1155 only
Old 04-25-15, 09:44 AM
Jonnybob
Jonnybob's Avatar
Default P1150 & P1155 - changed A/F sensor - now P1155 only
Had codes P1150 & P1155 so, of course, I did a search of the forum and concluded it was bank 2, sensor 1. Bank 2 was reported to be the bank facing the front of the car.
Easy enough repair. Ten minutes in and out with cleanup. However, after clearing the codes it is still throwing a P1155 (P1150 is gone)
I ran an ohm meter on the old and new sensors (all possible combinations). Only the new sensor had resistance, 4.5 ohms across the two black leads. My best guess is that this is the resistance of the heating element
Looking for suggestions for my next course of action.
Did I change out the wrong sensor?
Is there a common spot for the wiring to cause an 'open' circuit?
Did I get a new sensor which is bad?
Any assistance appreciated.
Jonnybob
Old 04-25-15, 03:11 PM
carguy07
carguy07's Avatar
Did you use an OE/Denso sensor or aftermarket?
Old 04-25-15, 06:39 PM
Jonnybob
Jonnybob's Avatar
Aftermarket....
I know, I know.
Old 04-25-15, 06:50 PM
matts6887
matts6887's Avatar
If i were you I would consider changing out that aftermarket sensor to a oem sensor because sometimes the aftermarket stuff can cause "issues" which it appears you already know about.
Old 04-26-15, 12:52 AM
artbuc
artbuc's Avatar
Originally Posted by Jonnybob
Aftermarket....
I know, I know.
What brand? It may help others to know. Thanks.
Old 04-27-15, 05:35 AM
Jonnybob
Jonnybob's Avatar
It was a no-name $32 part off ebay with a six-month warranty. Before I warranty the part I like to be sure I haven't missed something..
Old 04-28-15, 12:38 AM
artbuc
artbuc's Avatar
Thanks. Yep, this sensor had almost zero chance of working.
hoothoot
11-28-19 05:01 AM
S160dre
08-11-16 06:36 AM
edupim
01-28-14 10:51 AM
swat1727
10-01-08 11:50 AM
jacobzking
03-06-08 06:39 AM
Quick Reply: P1150 & P1155 - changed A/F sensor - now P1155 only
