What is this and worth fixing?
Old 04-19-15, 10:07 PM
wing0
wing0's Avatar
Default What is this and worth fixing?
While going under the car to do oil change.
I saw this:
What is this?
Should I somehow fix the mesh wires? with what?
I think this was damaged during winter driving.
Old 04-19-15, 11:30 PM
salimshah
salimshah's Avatar
this is the flex(ible) coupling in the exhaust piping. It isolates vibration and allows engine to move on its mountings without impacting the exhaust.
It seems you may have run over something and damaged it.
I would suggest that you have it checked by an exhaust shop. If there is a leak, it is a safety hazard as the silent killer CO and CO2 may enter the cabin and incapacitate the occupants.
Salim
Old 04-19-15, 11:49 PM
wing0
wing0's Avatar
Thanks for the information.
It's only the mesh wiring outside that has been torn.
I looked through the inside and everything is intact.
Can the coupling be replaced on its own without cutting/welding?
I was originally thinking of wrapping it with something.
Old 04-20-15, 03:24 AM
carguy07
carguy07's Avatar
You can buy a new Walker replacement pipe, some shops will also just weld in a new flex pipe. But if all that is wrong is the mesh is falling apart and it's not leaking, then forget about it and leave it alone.
Old 04-20-15, 06:35 AM
hypervish
hypervish's Avatar
Yeah, if only the mesh is falling apart, leave it.
My mesh was torn up for about 2 years, before my flex pipe let go due to RUST and actually started leaking.
You can see pictures of it here as well as a DIY to replace the entire flex pipe: https://www.clublexus.com/forums/rx-...placement.html
Old 04-20-15, 09:40 AM
wing0
wing0's Avatar
Well I live in an area where they use high amounts of salt in the winter.
Would it make sense to wrap it with some exhaust bandage to prevent salt from getting inside?
Old 04-20-15, 06:04 PM
Bobster999
Bobster999's Avatar
I had to order the same pipe a few days ago because something inside is loose and causing a loud rattling noise under certain conditions.
Old 04-20-15, 06:44 PM
wing0
wing0's Avatar
Did you order OEM(not even sure if they make it anymore)
or sometihng else?
Old 04-20-15, 07:45 PM
carguy07
carguy07's Avatar
I think anything you wrap it will will only make things worse and trap moisture.
Old 04-21-15, 05:03 AM
Bobster999
Bobster999's Avatar
or sometihng else?
went aftermarket from ebay. about $80 with shipping, gaskets and new nuts and bolts.
Lexus wanted about $440 for just the pipe. lol
thaeleelyr
01-16-13 05:21 PM
IS250TW
Performance
01-12-13 03:13 PM
david6249
06-10-12 01:24 PM
lowNslow
Performance
11-16-09 09:15 PM
llcoolpass
11-11-09 09:36 PM
Quick Reply: What is this and worth fixing?
