LED License plate lights
Old 04-15-15, 05:59 PM
2002RX
2002RX's Avatar
Default LED License plate lights
Is it possible to retrofit LED license plate lights into my RX300?
If not what is the closest "OEM" looking bulb I could get and where?
I don't want nothing crazy bright, however I do want the LED look.
Thanks, Tom
Old 04-15-15, 06:30 PM
hypervish
hypervish's Avatar
Yeah, it's as simple as pulling the old bulb out and installing a new 194 LED bulb.
Seeing as you're in NY, it likely wont be too easy to replace the bulb because the screws on the hatch will likely be rusted. If so, you will need to take off the inside hatch panels to access the bulb. There are instructions on here to do that, just do a quick search.
EDIT: Here are those instructions: https://www.clublexus.com/forums/rx-...e-removal.html
Old 04-16-15, 05:05 AM
2002RX
2002RX's Avatar
I have already been through the process of removing the rear door hatch interior panel and drilling the old ones out. I replaced the bulbs with regular 194 bulbs and stainless steel screws that time around.
I want to go LED this time, as it would be a simple install for me at this point, but can I take the LEDs from an RX 350 and install them into the 300? Has it been done before?
If that cant be done, what is a good "stock" looking LED bulb?
Tom
Old 04-16-15, 05:53 AM
hypervish
hypervish's Avatar
You need to find out which bulb the RX350 takes, and go from there.
This thread has some suggestions on LED's that may provide an OEM look: https://www.clublexus.com/forums/es3...te-lights.html
Old 04-16-15, 08:21 AM
matts6887
matts6887's Avatar
speaking of this; i just noticed that my right front side marker light(on the right front corner of the front fender) is out. How do I pop that sucker out so i can hopefully easily replace the bulb? also; what is the right part number for a stock bulb? Or is it better just to replace all 4 marker lights with led's at this point?
Old 04-17-15, 07:41 AM
2002RX
2002RX's Avatar
I believe you get to that bulb from inside the splash shield.
Old 04-17-15, 09:20 AM
matts6887
matts6887's Avatar
yea i kinda figured that when i looked at the inside splash guard. What size is the bolt that holds the splash guard in place?
Old 04-17-15, 10:32 AM
2002RX
2002RX's Avatar
10mm, you may need a philips head screwdriver as well
Old 04-17-15, 08:12 PM
matts6887
matts6887's Avatar
Thanks!; I will have to tackle this easy job(should be anyway) when i have some down time hopefully beginning of next week possibly.
Old 04-19-15, 09:41 PM
TaninAuto
Sponsor
TaninAuto's Avatar
We just got these in recently:
http://www.taninautoelectronix.com/T...s_t10_pure.htm
They work great in constant use locations and are actually white. No blue tint with these. The cheaper LED's start to flicker and fail if they are on for a long period of time.
__________________
TANIN AUTO ELECTRONIX
262-456-4147
contact@taninauto.com
Old 04-20-15, 12:04 PM
2002RX
2002RX's Avatar
Thanks, us the price per set or per bulb?
Do you have any pictures of them as licensed plate light bulbs?
Old 04-20-15, 07:38 PM
TaninAuto
Sponsor
TaninAuto's Avatar
__________________
262-456-4147
1halifax
NX - 1st Gen (2015-2021)
11-08-15 08:17 PM
SptDsgnGS
09-24-11 11:54 AM
Sheehan1p
06-05-09 10:11 PM
xknowonex
Lighting
11-03-05 01:07 AM
Quick Reply: LED License plate lights
