Instrument Cluster Drive Gear Indicator Light Out
Old 03-28-11, 12:19 AM
  #136
McCloud
McCloud's Avatar
I replaced mine a few weeks ago. Easy Breezy just like the instructions says.
Old 03-29-11, 09:19 PM
  #137
new2lexus2
new2lexus2's Avatar
If folks want one more DIY option, simply put a new bulb in the existing socket.
I used 12vdc micro lamps from Radio Shack http://www.radioshack.com/product/in...ductId=2103780
2 bulbs are $2.
Remove the old bulb by unwrapping the wire terminals from the base and pulling it out. Slip new bulb wire terminals into the small holes in the base and wrap wires once or twice and clip off excess.
Old 03-29-11, 09:24 PM
  #138
salimshah
Forum Moderator
salimshah's Avatar
Received 1,101 Likes on 991 Posts
2 bulbs are $2.
Did you do any home-work to ensure the replacement does not produce more heat? You dont want to ruin your instrument cluster.
Salim
Old 03-30-11, 06:26 PM
  #139
new2lexus2
new2lexus2's Avatar
they are 60ma and no noticeable warmth to the touch (tested them on external 12v battery) so not concerned with heat.
I would say they are not as bright as the OE bulbs, but plenty good enough to illuminate the indicators.
12v x .06 amp = .72w = no heat
Old 03-30-11, 07:11 PM
  #140
salimshah
Forum Moderator
salimshah's Avatar
Its good to err on lower side of heat, even if the light is not as bright. I wish I knew the specs of the OEM part.
Glad you found an acceptable and cheaper solution.
Salim
Old 03-31-11, 07:47 AM
  #141
jmezo
jmezo's Avatar
My drive lights been out for years. I dont miss it. Now if I can only get my ABS light to go out I would be even happier.
(Sensors dirty... relay pulled)
Old 03-31-11, 09:55 AM
  #142
salimshah
Forum Moderator
salimshah's Avatar
I would always advise people to have the lights in working condition.
I was once involved in freak accident, where a 18wheeler backed up on me. I roved through gears to get in the reverse and with your vision playing tricks on your mind (all I could see was the frame of the trailer get bigger), having the dash light showing me the gear selected helped.
In a manual (non-automatic), you mind learns the gear you are in by the position of the stick .. not so in the auto-trans .. and specially RX with its unique lever position.
Salim
Old 03-31-11, 11:52 AM
  #143
jimparr1
jimparr1's Avatar
Easy fix. The dash cover is very easy to take out with a screw driver. The bulb is burnt out and only available at a Lexus dealer. I would take the bulb out first and have the dealer match it. My experiance is there are several different bulbs in the dash and even the dealer is not sure which one is correct. Once again the dash cover is very easy to remove and the bulb is about $6.00. I bought an extra because my dealer is about 60 miles away.
Old 04-01-11, 07:01 PM
  #144
MikeS99rx3
MikeS99rx3's Avatar
Originally Posted by lexus ASM
Congrats to all who fixed this themselves. If you are going to do it, I recommend an LED bulb. You wont ever have to replace it again.
Any idea what kind of led would work? whats the size or part number, other than dealer?
Old 04-17-11, 12:48 PM
  #145
00LexusRX
00LexusRX's Avatar
I got a set of 5 incandescent bulbs with the base that works with the RX dash. The cost is $1.00 and shipping/handling is $7 from All Electronics. I order a lot of electronic parts from this source, they are reliable. With the time savings and the price of gas not a bad deal....
http://www.allelectronics.com/make-a...SE-LAMP/1.html
Old 04-18-11, 02:20 AM
  #146
McCloud
McCloud's Avatar
Wow! Thanks a lot 00LexusRX! Great job!
Old 05-06-11, 05:42 PM
  #147
Ryan300
Ryan300's Avatar
THANKS FOR ALL THE GREAT DIY!
1. tranny fluid drain/fill.
2. cabin filter replacement.
3. D drive light bulb replacement
Next I want to switch the arm rest because the drivers side armrest has depression from pressure of my elbow. I'll switch armrest by turning them upside down on installation. I think it may work.
Old 06-06-11, 12:46 PM
  #148
dtewing
dtewing's Avatar
Default Great Tutorial and Pics
Comfortably made the swap of the burned bulb and new one from the stealership. Although I used their only quote request and it was only $3.55.
Took me about 15 minutes total.
Thanks Club Lexus community for ALL your help....
Darren
Old 06-06-11, 01:37 PM
  #149
TriniLex
TriniLex's Avatar
2. Pull trim piece straight out on the left of the steering wheel, the trim that houses the seat memory switch.
3. Pull trim piece straight out that is around the key.
Any tools I should use? or just grab and pull?
Old 06-06-11, 03:48 PM
  #150
salimshah
Forum Moderator
salimshah's Avatar
If you take the bezel "black plastic piece around the the instruments"; which is held by 2 screws (top edge) out first, you can grab the two pieces quite easily. I would not use any other tool. As you pull out each piece, examine the bayonet clips .. align the metal pieces if needed.
Put a towel/cloth on top of dash. This will allow you to place the cluster on the dash without damaging it.
Salim
Quick Reply: Instrument Cluster Drive Gear Indicator Light Out
