RH Rear Speed Signal (Sensor)
Is there a DIY for replacing the rear speed signal or sensor?
Has anyone else done this and could give me basic information?
Thanks
CEL - VSC lights on and codes read:
C0210 - Right rear speed signal
C1223 - ABS Malfunction
2001 RX300 Silversport
Thanks
The electrical connector for the rear is behind the trunk panel though.
Salim
Salim
First I must say that I have not accessed the connector. You can guess that it will be within few inches of the place where wires enter the body.
Since the panel is a large piece, just take it out.
I am not sure if there is a DIY which shows how to take the panel out.
Salim
Salim
rick
Salim
Hello Rickl289: I have replaced RR ABS speed sensor in the wheel well and I am looking for a way to access the inside connector behind the RR back seat. The plastic panel wall has 2 pieces: one on top reaching the height of the door top edge and the other piece is at the seat level. I trust that the inside connector is behind the back seat in the photo from where the RED arrow points to.
If you can, please describe in detail how to remove the lower plastic panel. Mine is a 2000 RX300 model and plastic parts are getting fragile. The top edge of the lower plastic panel appears to tucked under the lower edge of the top plastic panel. Are the 2 pieces inter locked at the edges? (In the photo I yet to remove the back seat, but will get it removed shortly.)
