timing belt water pump and accessory belt Q's
There is no sticker on the timing belt cover from the factory, so If there is a sticker, there's a very high probability it was done. I'd worry about the timing belt at around 180k miles in your instance.
Just had all belts replaced by Lexus of Naperville in Illinois, in my 2002.
I was charged $955 for the timing belt, water pump and all other drive belts.
They also suggested crank and cam seals (for $254.04). Should I do that at some point in the near future?
The car has 113K.
The car has 113K.
The car has 113K.
The car has 113K.
These seals are usually good for many, many miles, however I recommend they be changed at the second timing belt replacement.
Well; the thing is; how can I get complete records if normal maintenance and other repairs etc were done at a independent shop? A lexus dealer probably wont have those records if a independent shop did all the work etc. So Where would i go from there? Is there a way they can get that info even if a different shop worked on it?
Salim
The car has 113K.
The car has 113K.
1. Timing belt every (90k-110k)
2. Idler/roller along with timing belt [there is no lube for them]
Examine the things listed below at every T belt change, but replace them in every other T belt change
3. Tensioner
4. Waterpump [or sooner if you have not maintained your coolant or have used something other than toyota red/pink]
5. Front main seal, and Cam seals.
Items 3-5 can fail anytime, so you carry the risk of paying/doing the labor the second time in shorter interval. The Above is just one persons opinion.
Salim
Saw this post just now. Thanks hyper. Yea i kinda thought there was a chance that it had been done because there is a sticker on it. And indeed i will wait til around 180,000 to change it. thanks hyper.
I can share what I do, but this is not a hard and fast rule to follow dealing with timing belt chain ... the acc belt has 45-60k interval change. I only use OEM
3. Tensioner
Salim
3. Tensioner
Salim
Matt:
It seems the belt was replaced, so wait till 200k miles. If any thing leaks then you will have to get in and address it. The belt itself is about $45, so if you open (or have it opened up) for the repair, replace the belt sooner that 200k.
Rear main seal is on the far side. That you deal with when transmission is separated. If that seal leaks, one should try alternatives repair methods or even live with the leak till it gets to a point that the repair is a must.
Salim
Salim
Yes; I know about the rear main seal. Those can be a royal pain in the you know what to replace because like you mentioned; ya gotta separate the trans from the engine to get access to it. And that is something i definitely dont have the tools or facilities to do it with so i probably will have no choice but to get a shop to replace it. But unfortunately with that we are talking big bucks to do it. But if it ever happens and it gets to the point of needing replacement because of severe leakage etc. then i will have no choice but to pay a shop to do it.
ilcitdream
10-05-15 09:01 AM
lexus114
RX - 1st Gen (1999-2003)
03-05-08 07:56 AM
