Starting problem. any ideas requested..
Old 11-23-14, 06:52 AM
beachlover
beachlover's Avatar
Default Starting problem. any ideas requested..
So, the weather has turned cold, here in Toronto, and my 2000 RX300 has been weird on starting first thing in the morning. As I turn the key from run position to start position, it's only clicks once and no start. But will start after about 4 or 5 tries. And starting the rest of the day seems fine. I've eliminated that it might be the key, since I tried another key, same issue. And same whether in park or neutral, so don't suspect that switch. Charging system seems fine, no alt light, nor codes being thrown.
So, my guesses are:
1) battery connections, although they look good. Warms up Monday, so will redo anyways. Battery is only year old.
2) starter, something internal?
3) ignition switch ( the worst diagnosis, to me) cause I have lots of miles, and plenty of starts, and have to do that screwdriver trick every year when it gets stuck on accessory. But would think that then problem would be there during the day.
Any ideas?
Old 11-23-14, 09:37 AM
salimshah
salimshah's Avatar
Please read the sticky "Having problems start here mega thread".
Most likely it is the starter solenoid.
Salim
Old 11-23-14, 06:06 PM
carguy07
carguy07's Avatar
http://www.nationsautoelectric.com/instructions.html
Old 11-23-14, 06:10 PM
JAB
JAB's Avatar
How many miles? My 1999 RX has 220K and I have rebuilt the starter twice. Simple and inexpensive.
Old 12-03-14, 02:50 PM
DewHawk
DewHawk's Avatar
My did that as well and I had to replace starter. I was told starter had a flat spot..
Old 12-05-14, 09:38 PM
JAB
JAB's Avatar
Flat spot? BS. What happens is that the solenoid contact wears out. The part is $7 and can be easily replaced, but the dealers won't do it; they insist on selling you an entire starter.
chipmcclur
GX - 1st Gen (2004-2009)
01-14-16 04:47 PM
sexilexi
Maintenance
06-17-06 07:10 AM
99jewel
15
06-28-05 09:52 AM
doule
12-09-04 06:15 PM
LB Lex
GS - 1st Gen (1993-1997)
07-17-03 12:12 AM
Quick Reply: Starting problem. any ideas requested..
