RX 300 hard to starts
Old 09-22-14, 05:39 AM
btheurer
btheurer's Avatar
Default RX 300 hard to starts
cranks good but doesn't start good. Crank for a short time and then i've got to wait about 20 seconds and try again. could it be the fuel pump? or a electrical proble?
Old 09-22-14, 05:44 AM
fifaref2
fifaref2's Avatar
Following. No good guess. Wait for,the pros
Old 09-22-14, 07:11 AM
2GSKaizen
2GSKaizen's Avatar
How many miles are on the car? Could be in need of a tune up. To break it down to basics, you need 3 things to get the engine to run. 1. Compression, 2 Spark, and 3 Fuel. If you haven't replaced your spark plugs in a very long time, this could be affecting the spark. If your fuel pump is getting weak, this could also be a problem. What I would do is 1. When you get in the car to start it next time, instead of sticking the key in and immediately cranking the engine over, turn the key just to the on position and let it sit for a few seconds. cycle the key back off, and then back to the on position. This is turning the fuel pump on. After a few times, then go ahead and crank the engine. If it starts quicker than it has been, I would suspect a fuel pump. A weak pump might not have the ability to create enough fuel pressure if you just hop in and crank the engine right away. Priming the fuel pump a few times as just described is basically giving the pump a few ignition cycles to build up the required pressure in the fuel system. Try this procedure the next few times you start the car. If you find that this is helping the car start quicker, suspect a failing pump. Also try it a few times the old way of just cranking right away. Try to develop a consistent pattern. It should be fairly obvious if this priming the pump beforehand is giving you better results. Report back and let us know if this is helping.
Old 09-22-14, 08:37 AM
salimshah
salimshah's Avatar
First a warm welcome to CL btheurer.
Adding on to an excellent post of 2GSKaizen ... you need air (Oxygen) ... these days the fuel is slave to the oxygen. Does it help to start if you have the gas pedal depressed partially? And are you getting any CEL?
Salim
Old 09-26-14, 12:43 PM
btheurer
btheurer's Avatar
change fuel pump had no problems, start up and ran great. then next day doesn't start again. help
Old 10-01-14, 06:12 AM
pilot2
pilot2's Avatar
how many miles on the plugs and ignition wires?
Old 10-07-14, 09:53 AM
btheurer
btheurer's Avatar
Default hard to start
Re-installed fuel pump and works great. must of had a bad connection when I first put the pump in.
tarheeldad
05-21-15 11:42 AM
anu7898
Performance & Maintenance
08-13-13 01:43 PM
BUN430
Maintenance
05-31-11 03:35 PM
dreamsc300
10-24-10 05:09 PM
ecalica428
12-21-06 01:57 AM
Quick Reply: RX 300 hard to starts
